1 members (1 invisible), 105 guests, and 3 robots.
Topics128,089
Posts1,056,440
Members48,443
#863847 07/02/2012 11:54 PM
The hood on my truck has some severe rust in the usual spots. Last year I purchased a parts truck and the hood on it is nominal too. I have decided to try and make 1 good hood out of the two. I drilled spot welds today on the donor hood and hope to prep and weld my original hood tomorrow. Any body have any opinions on patch panels from LMC truck? I will be needing patch panels for my doors and cab, any feed back about quality vendors would be appreciated.
http://i1185.photobucket.com/albums/z342/BigRicks66/IMG_0306.jpg
http://i1185.photobucket.com/albums/z342/BigRicks66/IMG_0304.jpg
http://i1185.photobucket.com/albums/z342/BigRicks66/IMG_0308.jpg
Richard Morgan
1966 Chevy C10 LWB Stepside
More pix on Photobucket
Had a fairly productive day on the hood. I still have some repairs to do at the rear of the hood but it looks so much better with the front panel replaced.
http://i1185.photobucket.com/albums/z342/BigRicks66/IMG_0315.jpg
http://i1185.photobucket.com/albums/z342/BigRicks66/IMG_0313.jpg
http://i1185.photobucket.com/albums/z342/BigRicks66/IMG_0316.jpg
Richard Morgan
That's some quick repair work. My hood is in better than average condition for a 65. However, I want to remove the front piece to get to a dent and to also get some POR15 into the hidden areas. I'll sleep better knowing that I won't have to deal with rust coming through from the other side. I might ask you for more details later.
Nice work! Keep at it!
Lugnutz #867924 07/19/2012 6:26 PM
Removal of the front panel was surprisingly simple but very labor intensive. You have to drill a lot of spot welds. I should have taken more pictures during the process to help others. I am going to do a similar process on the rear of the hood and I should end up with a fairly solid hood.
Richard Morgan
