| | | Forums66 Topics128,091 Posts1,056,038 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2011 Posts: 26 New Guy | | New Guy Joined: Jul 2011 Posts: 26 | I check the voltage at the generator and there is no voltage there, is this a sign of stuck or bad brushes? The generator was working fine until I adjusted the belt that was squelling. I still have about 3/4 inch of slack in the belt, and it still squells when I rev it up. I checked the voltage at voltage regulator and I see the battery voltage and nothing else.
DR
| | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | if it worked before, should be working now.. try a new belt and tighten it up, that seems like a lot of slack but I always adjust them to my feel,some slack but not bone tight
might also be gen squeaking but that would be easy test by taking belt off and listening
Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Jul 2011 Posts: 26 New Guy | | New Guy Joined: Jul 2011 Posts: 26 | What is the chances that the air gap in voltage regulator needs adjustment? I check the gap and they seem off, I did check the output of the generator again and it seems to increase in voltage after a minutes. I did remove the leads and cleaned them. Should I see movement in the amp guage? What is the proper way to adjust the gap? DR | | |
