3 members (Shaffer's1950, Uncles51, baldeagle), 97 guests, and 1 robot.
Topics128,026
Posts1,055,408
Members48,422
#863896 07/03/2012 3:16 AM
Tonight I decided to started cleaning up the 4 speed, and dissect the leaking Muncie P2HX PTO.
I've read seal replacement is fairly easy on these units, but I'm looking for the pointer in the right direction!
I have it to this point...
<pic>
<pic>
<inside>
Need I remove the shafts to pull the seals? And if so, how??
As far as I know the seals are
- Timken 480821 or Chicago Rawhide 7474
- Timken 480889
but I can see a national number one, 50800.
Mark
I always did take them completely apart so I could thoroughly inspect all the parts and replace the freeze plugs at the same time. It is a Muncie manufactured by Chelsea. Muncie didn't begin to manufacture PTO's until approx. 15-18 years ago.
The advantage to this for you is it makes getting the parts that much easier.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
Dave,
I'm all about taking it apart - but not sure where to begin!
Ok, I have both plugs out - do I press the shafts out from the plug end?
Mark
Well I got impatient and thought I would give it a try... I used a punch and first knocked the drive line out - removing the seal while doing so.
But the engagement pin drove out the opposite way! After which I removed that seal.
I can also make out the seal #'s so I think I'm good to go, although I've never heard of a "Victor" seal, hopefully my local guy can cross reference.
