11 members (Jay R, wilbur53, Gdads51, TUTS 59, DaveV, RLB, WICruiser, Phak1, Otto Skorzeny, 55shaker, 1 invisible), 109 guests, and 4 robots.
Topics128,056
Posts1,055,789
#864058 07/03/2012 8:02 PM
Hi all from the very wet UK
I have a 54 3100 with a 350 chevy with a edelbrock performer manifold and 1604 carb.
The truck starts great but i have issues pulling away from junctions, lights etc.
The truck bogs down then picks up, or will backfire through the carb and nearly stall. I have put the accelerator pump in the top hole for more of a squirt but this does not help.
I think im running lean off idle and was going to up the metering rods one stage richer (23 in the tuning graph)what do you all think ?
if it ain't greasy it ain't diddly
english54 #864061 07/03/2012 8:39 PM
Did you check to make sure the timing is not too far advanced?
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
to be honest, i have not checked it for a while, will get on to it, when it stops raining!
thanks
english54 #864113 07/04/2012 12:14 AM
english54, timing would be a good starting point. The edlebrock is one of the simplist carbs I've seen. They usually have a video with each new carb that shows a guy taking one apart and how to adjust one if your not familiar with them. If you don't have one I'm sure some garage or friend should have one laying around out of a new box.
As FYI one of the things that Edlebrock cautions folks about is changing the metering rods "willy nilly" and they tell you if your going to change the rods to use the guide in their book, which I think your are, to make sure they "match". I've never had to work on one other than adjust it just a little, when I got the engine running. I have one on my 37 for over 10 years without any problems except the gas gummed things up after sitting for a long time. I took it apart and cleaned it and it ran just find. I also put one on my panel and for "out of the box", and for the money, they are hard to beat. Biggest problem some folks have is OVER carbureting and engine!
Good luck let us know what you find.
