3 members (Lostbuthaulinass, Otto Skorzeny, Nick in Manitou), 81 guests, and 2 robots.
Topics128,029
Posts1,055,417
Members48,422
Apprentice
Apprentice
1 Offline
Hi all,
Im new to this forum, but was wondering if you all had a web page or a very detailed email that you all can send me on how to wire a kill switch inside the cab for security reasons. I would like a diagram or pictures to help me out. gthaman06@hotmail.com
You can do it with one toggle switch, two wires, and two connections. email me for details.
[email protected]
You can use a DPDT switch, using one set of contacts to break the "start" wire to the starter from the ignition switch, Then use the other side of the switch to ground out the points, by connecting a new wire to the ignition coil to the same spot on the coil as the wire from the distributer connects (this is where a Tach would connect). This way even if someone does try to hot wire the truck and jump the starter under the hood it will take a while to figure why they have no spark! If you have an electric fuel pump you can also put a switch on that too.
