Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (Rusted Nut, 59 fleet, Otto Skorzeny, 1 invisible), 236 guests, and 5 robots.
Topics128,282
Posts1,058,497
Members48,490
Just installed a new 3 Prong LED Flasher on my 52'. I have LED taillights out back and regular 2-wire parking lamps out front. The turn signals work perfect while the engine is NOT running, however, once I start the engine, the turn signal flasher blinks once and then blinks double and just acts strange as if something is interrupting it. Do I need a voltage regulator in line before the flasher? (My truck is converted to 12 volt and has an alternator)
Try installing a standard 12 flasher.
You should only need the LED flasher if your running LED's front and back.
Good luck
I tested the voltage to the light switch (power source) and when the engine is OFF, the multimeter reads 12.2 Volts. When the engine is running, the multimeter reads 11.84 volts. Could this cause the 12V flasher to stop working because it's under-powered? What would cause a drop in voltage while the engine is running?
Riding in the Passing Lane
Sounds like you have an alt. problem. The voltage should be about 14 volts with a well charged bat. with the engine running. If the bat is a little low it will be about 13 & slowly work up.
1972 Chevy c10 Cheyenne Super
I'll take the alt. and have it tested.
Thanks for the info!
After testing the alternator at the local parts shop, found out it was bad. Now I'm getting 14 volts with the new one. The flasher still wasn't working after installing the new alternator, so I dug out the old 2 prong regular flasher and it works! I'm gonna pick up a regular 3 prong flasher this week so my indicator light will function. Wish I had asked this question before I ordered the heavy duty LED one!
Thanks for your help
