| | | Forums66 Topics128,130 Posts1,056,367 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2007 Posts: 321 Shop Shark | | Shop Shark Joined: May 2007 Posts: 321 | So I now have 400 miles on a fresh 261 rebuild. When do you think I should recheck my valves? I was thinking anytime now would make sense. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Patrick,
Wait to hear from the more experienced members, but I was "taught" years ago to tighten head bolts and check valve clearances after 500 miles (on a newly rebuilt mechanical-lifter head/engine).
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Told same as Tim. I found 2 loose pan bolts too. My on fault likely.Probably didn't go back and tighten them when mounting the pan.
Drew
| | | | | Joined: May 2007 Posts: 321 Shop Shark | | Shop Shark Joined: May 2007 Posts: 321 | That was what I was taught as well, but wanted to double check. Drop the oil, recheck head studs (Already did after cam break in too) and all that other good stuff. | | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | 500 miles. But it is CRITICAL that you make sure everything is good and hot before you go over the valves.
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | |
