3 members (Hotrod Lincoln, Bill Hanlon, Gdads51), 141 guests, and 2 robots.
Topics128,109
Posts1,056,271
Members48,439
So I now have 400 miles on a fresh 261 rebuild. When do you think I should recheck my valves? I was thinking anytime now would make sense.
Patrick,
Wait to hear from the more experienced members, but I was "taught" years ago to tighten head bolts and check valve clearances after 500 miles (on a newly rebuilt mechanical-lifter head/engine).
Told same as Tim. I found 2 loose pan bolts too. My on fault likely.Probably didn't go back and tighten them when mounting the pan.
Drew
That was what I was taught as well, but wanted to double check. Drop the oil, recheck head studs (Already did after cam break in too) and all that other good stuff.
ODSS Lawman
ODSS Lawman
500 miles. But it is CRITICAL that you make sure everything is good and hot before you go over the valves.
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
