5 members (3800GUY, Uncles51, Gdads51, J Lucas, Otto Skorzeny), 94 guests, and 2 robots.
Topics128,127
Posts1,056,674
Members48,450
#862466 06/27/2012 5:56 PM
Can anyone advise me regarding rearends that would be a good fit in a 1946 GMC 1/2 ton .
Allan
1946 GMC
1949 Mercury M68
Crusing in the Passing Lane
Don't 4WD S-10's have about the right width axle, 6 bolt pattern, 2WD S-10's have a slightly narrower tread.
All S-10's are 5-bolt, whether 4WD or 2WD.
My 46 GMC on Photobucket
This is good to hear as I am currently stripping a 95 S10 for parts . I was planing to use the 4.3 V6 and T5 tranny so perhaps I will retain the rearend as well .
Allan
1946 GMC
1949 Mercury M68
YES!! keep the rear and go to jc whitney for the 1 3/4 spring perches, they get welded 4 1/8 in. from the backing plates and you can use you're original springs....i just finished doing that to my 46 1/2 ton i have pics, I even lowered mine by removing 4 leaves from the bottom of the springs and cutting them down and installing them on top of the spring ....i just tore out my torque tube drive and put a t-5 in mine with a custom made driveshaft (cut down 79 olds cutlas driveshaft)...make sure you use the plates from the s-10 for the u bolts on the rear,i have pics to checkout
