| | | Forums66 Topics128,136 Posts1,056,430 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 152 Shop Shark | | Shop Shark Joined: Jan 2011 Posts: 152 | Does anyone have a picture or a diagram of the tail pipe for a chev. 1-ton with 9ft. bed? I need to have one made, and want it to be like the original. Thanks, Terry
49 chevy 1-ton. It is a work in progress but it's getting close. 49 1 Ton Pics | | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | Do you have a factory assembly manual? Maybe there is an illustration in there. I don't have mine handy right now. | | | | | Joined: Nov 1995 Posts: 5,723 24601 | | 24601 Joined: Nov 1995 Posts: 5,723 | Terry, I'll go take some pictures of mine in a few minutes and get 'em loaded up tonight. Here they are My truck is unrestored and only has less than 60,000 Tennessee miles on it (about 2,000 Maryland miles). I'm *assuming* that's the original muffler and tailpipe but I can not confirm it. The tail pipe does match what I see in the assembly manual, though. It is not quite in it's proper location, though -- it needs to be more to the driver's side frame rail to clear the spare tire carrier (once that's installed). I just got the parts to put the muffler and tailpipe back in it's proper location  I hope this helps. Regards, John
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: May 2006 Posts: 934 'Bolter | | 'Bolter Joined: May 2006 Posts: 934 | on my 1 ton a short pipe was run just past the running board step exhausting just behind the cab. But this 1 ton is a flat bed if that makes any difference. | | | | | Joined: Jan 2011 Posts: 152 Shop Shark | | Shop Shark Joined: Jan 2011 Posts: 152 | Thanks to all of you, I used the info. and had one made. Terry
