1 members (Materman), 107 guests, and 3 robots.
Topics128,072
Posts1,055,906
Members48,429
#861770 06/25/2012 3:51 AM
Custom Title
Custom Title
I had another thread going asking which gen I needed to use to convert to 12V while retaining a generator. I was told one from a '56 and up truck is the one. I need the serial or model number of this unit. I called a local electric shop and the guy has a million different ones on the shelf and he's not sure which one I need. Anyone help?
49 Chevy 3600
65 Chevy K10
48 International KB-1 Service Truck
55 Willys CJ5 - Chevy 331 powered
26 Model T Roadster Rat Rod
70 Tucker Sno-Cat 442-A
96 Dodge 3500 Cummins dually flatbed x-cab 4x4
06 Jeep Wrangler LJ rock crawler
If you can't fix it with a hammer, it's an electrical problem
model numbers will vary [that page and the following] depending on the output [about 25 amp standard, or 30a, 35a, 55a, etc] - what you want is a Delco generator with a red tag that says 12V, not too tough .... and a 12V voltage regulator [new are Standard brand VR22 or VR24 I believe] .... it will look almost identical to the 6V generator so maybe you could take that in and show them, if they can't figure it out maybe they don't know enough to deal with ohwell
