1 members (delky),
65
Mod | | | Forums66 Topics128,049 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2004 Posts: 266 Custom Title | | Custom Title Joined: Nov 2004 Posts: 266 | I had another thread going asking which gen I needed to use to convert to 12V while retaining a generator. I was told one from a '56 and up truck is the one. I need the serial or model number of this unit. I called a local electric shop and the guy has a million different ones on the shelf and he's not sure which one I need. Anyone help?
49 Chevy 3600 65 Chevy K10 48 International KB-1 Service Truck 55 Willys CJ5 - Chevy 331 powered 26 Model T Roadster Rat Rod 70 Tucker Sno-Cat 442-A 96 Dodge 3500 Cummins dually flatbed x-cab 4x4 06 Jeep Wrangler LJ rock crawler If you can't fix it with a hammer, it's an electrical problem | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | model numbers will vary [that page and the following] depending on the output [about 25 amp standard, or 30a, 35a, 55a, etc] - what you want is a Delco generator with a red tag that says 12V, not too tough .... and a 12V voltage regulator [new are Standard brand VR22 or VR24 I believe] .... it will look almost identical to the 6V generator so maybe you could take that in and show them, if they can't figure it out maybe they don't know enough to deal with  Bill | | |
