8 members (Nick in Manitou, Guitplayer, Chip O, Alex52, Bill Hanlon, HandyAndy, TGP, Charles in CA), 72 guests, and 1 robot.
Topics128,208
Posts1,057,452
Members48,471
Y
Y Offline
http://s1073.photobucket.com/albums/w387/Hamilton235/
I just had the exhaust put on my truck yesterday. I was able to take a few pics but I was asked to hurry due to having another cuatomer in line for some work. They are not the best but some are good and show some of the detail. Hope you like!!!!
Looks good. Will you be adding this exhaust pipe heat shield under the bed wood where the exhaust "humps up" under the bed?
Y
Y Offline
Yes I will be. I have a piece of stainless that I'm going to form and make my own. I should have the truck completely finished up by the end of this weekend if everything goes well. I told the exhaust shop to leave about 4 inches between the bed floor and exhaust system at any point but you know how that goes...After I questioned him about it he told me that the tail pipe will not get hot enough to hurt the wood floor. i then asked well what about the finish on the wood? His reply was let's hope not....
I will not be using them again for sure. He did the job the way he felt it needed to be done not as I asked. By the way he made the comment I've never put an exhuast on a truck with a wooden floor in it before it looks nice. I said lets hope it stays that way if not I hope you have some wood working abilities!!!! Long story short now I need to drop it down a few inches and make the shield to protect my bed. This was the only portion of the project that I have had someone else do and of corse I have to fix it...LOL If you want it done correctly you've got to do it yourself!!! OK done venting!!!
Dude, you're killin' us!!! Your truck looks like it just rolled off the assembly line. And mine?? Not even close.
It looks too good! But then again, I'm jealous.
Chuck
1941 Chevy coupe
1938 Chevy coupe streetrod
Wait for others to comment but considering how close they got the exhaust to the bed wood, I would consider aluminum over stainless. Aluminum disapates heat better...just a thought and only opinion.
Your truck looks great!
Yep, your truck is making a lot of us envious. smile Hope the exhaust rework won't be too tough to do.
Drew
Y
Y Offline
Thanks for the compliments. I will be able to drop it and use a heat shield. It was a frame off over the last 3+ years and everything is new or restored befor putting it back on the truck. I've never invested in a tube bender due to only needing one every couple of years so i just pay for the exhaust work. I may now cause I just noticed they broke the tab on the manifold and tried welding it up. Looks like (*). I foung a nice manual hydraulic unit for $200 that i may pick up. They must have used an impact. I tightened down the old exhaust by hand and the manifold was fully inspected before painting and putting on the motor. I have a spare motor so I will have to swap the manifolds.
I'm very picky on my work and am called a perfectionist all the time. LOL It sometimes causes me hours of extra work but to me it's what separates the nice cars from the awesome cars. Thanks again for all the compliments.
Y
Y Offline
Thanks, I will be under the truck tomorrow. I think I can drop the exhaust about 2 inches and add the shield. Good idea on the aluminum. I may have some sheet left.
Is that stainless pipe? Did you ceramic coat it?
Does it have an engine in it? lol
No pics under the hood.
~Jim
Y
Y Offline
It's just standard galved pipe. Nothing special. As much as it will see a wet road it will probably never rust. It does have an engine. 235 I6. I will be adding some engine pics soon.
