3 members (DaveV, Phak1, TUTS 59),
223
Mod | | | Forums66 Topics128,162 Posts1,056,942 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2009 Posts: 10 New Guy | | New Guy Joined: May 2009 Posts: 10 | Does anyone know if there is a source for the bolts with the large cup washers for the rear fenders?
Good substitutions? | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Post a picture. What about using fender washers?
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Sorry, I know what you are referring to. I have never seen them for sale. Let's see if some one comes up with a source.
| | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | EDIT: I SEARCHED AND SEE THAT YOU HAVE A SUBURBAN. DISREGARD THE INFO BELOW WHICH IS FOR A PICKUP. Looks like the part you need is a combo bolt and lockwasher (GM #3676478 in the Factory Asssembly Manual) This is probably not the parts that you need, but just in case they are ... The Truck Shop, 47-1101 clutch head bolts, nuts, washers kitThe Filling Station Enter part number in "Search by part number" boxMK-48, Phillips head screw GM-1254, Clutch head screw TR-222, Clutch head bolts, nuts, washers kit Classic Parts Clutch head fender kitindividual clutch head bolts: 37-975 individual Phillips head bolts: 37-978 individual polished Phillips head bolts: 37-978P individual stainless Phillips head bolts: 37-978S
Last edited by LonnieC; 06/23/2012 2:45 PM. Reason: Gave info for pickup / not sub
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Lonnie,
The panel-body rear-fender bolts and washers are completely different from the pickup's. They are not typical fender washers and the bolts are indented hex head without flange.
If Snubby does not post a few photos, I'll take one off my Suburban and post a few photos.
The bolts are available (even stainless from Totally Stainless); however, I have never seen the heavy/thick cupped serrated/starred washers for sale.
| | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | Wasted some more time searching. Nothing good ... I found one source for #3676478: Collectors Auto Supply $3.00 ea Part numbers listed in order Description says "Clutch Head Bolt" and does not mention the lock washer. The diagram in the FAM shows a hex head bolt. Other info: #3676478 BOLT ASSY w lock washer 5/16-18 X 1 Shown on Sect 11, Sheet 20.00 1947-1954 FAM '29-'54 MPC Group 8.206 Part 3676478GM Parts Wiki 1GM Parts Wiki 2Chevs of the 40's lists the part number, but it is not the correct configuration
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Mine are not clutch head bolts (I dimly recall).
I'll see how easily I can take one off to photograph.
Some of those part numbers are surely correct.
added in edit:
I was wrong about the indented/recessed hex head. It is a plan hex head bolt (they are captive with the washer and are not stainless, so I do not think that I changed them).
I have photos that I will post in about an hour. I have to take my daughter to her wedding shower - I was not invited.
Last edited by tclederman; 06/23/2012 4:18 PM. Reason: correction/clarification added
| | | | | Joined: May 2009 Posts: 10 New Guy | | New Guy Joined: May 2009 Posts: 10 | Thanks for all the searching guys. Yes, suburban/panel rear fender bolts appear to be quite different than the trucks. Which makes sense, given the difference in the way it mounts. Here's a photo that shows what I believe to be original parts. I don't believe this has been removed. I've also taken a fender off another panel that had these very same bolt/washer combo. Suburban/panel fender boltstclederman: Your link is broken for me. I actually haven't been able to access that website for some time. Am I the only one? | | | | | Joined: May 2009 Posts: 10 New Guy | | New Guy Joined: May 2009 Posts: 10 | Looks like newer style body bolts would be a good substitution. Dorman makes these. . . . . | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Snubby,
Try clearing your browser's cache and/or history.
From some locations (some ISPs), I have had to change my network settings for the DNS to a reliable DNS server maintained by Google:
8:8:8:8 And/or 8:8:4:4:
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Your bolts look like what I had thought my bolts looked like, indented/recessed hex head.
They are available without the flange.
Even if the flange head bolt or the original washer is used, I like to spread the pressure through a fender washer.
| | | | | Joined: May 2010 Posts: 74 'Bolter | | 'Bolter Joined: May 2010 Posts: 74 | If anyone is a stickler for originality, I have a few of these that came off my '53 panel. PM me and I can give you more details. No they are not new, but they might be useable, and the price is right (free). | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | dh53,
These should go fast. When they are gone, let us know.
Would interested people directly contact dh53 via a Private Message?
