| | | Forums66 Topics128,109 Posts1,056,271 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2000 Posts: 591 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 591 | I posted this in the bed forum but I don't think it gets as many visitors as this one.
I have a 1957 Chevy truck, long-bed. I am about ready to assemble the bed. It has been apart so long, I forgot how the mounting brackets for the bed side steps (gravel shields) bolt in. It looks like they bolt to the front sill (closest to cab), back side (to the rear) of the sill. The sill has two holes on each end, on one side. I think the sill needs to be positioned so the holes side faces the back of the truck. The sills are from Mar-K. Can anyone verify this or take a quick look under their Task Force truck? Thanks. don | | | | | Joined: Sep 2010 Posts: 166 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 166 | My 59 is also a Mar-K bed with orig steps and brackets. I mounted mine like you stated; front cross sill w/ holes to rear of truck. Brackets with the concave side facing front of truck. Darren | | | | | Joined: Jan 2000 Posts: 591 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 591 | Thanks Darren, much appreciated. Very nice truck by way, beautiful job. don | | |
