| | | Forums66 Topics128,029 Posts1,055,417 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 22 New Guy | | New Guy Joined: Jul 2006 Posts: 22 | I'm trying to find the dimensions of a Carter YF metering rod..75-749 OR is there a list of published dimensions I could refer to?? Any help would be greatly appreciated. Thanks.
Pizza40
| | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | I'm sure someone will probably chime in with an exact answer but until then ... If you can't find it at the following link,shoot them an email. http://www.thecarburetorshop.com/Orderinfo.htmThe owner goes by Carb King on the forums. | | | | | Joined: Feb 2000 Posts: 5,195 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,195 | | | | | | Joined: Nov 2002 Posts: 2,763 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,763 | Got your email. But since you also posted here, I will give the answer to the email here as well.
With all due respect, this is a question I won't answer. No, I am not trying to keep the information to myself, rather it is a matter of time. The dimensions are found ONLY on the original blueprints/drawings which are on microfilm. It would take an hour or so to retrieve the information, and present it in a usable form. And spending that hour could result in about 3800 identical questions for other metering rods.
As far as general specs:
Effective length 2.40625 High vacuum 0.0715 Midrange 0.062 Low vacuum 0.045
And even Carter did not have a comprehensive chart (at least it doesn't exist in the factory records in my possession).
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Apr 2006 Posts: 506 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 506 | For the Carter 937S carb,
75-749 is Standard 75-783 is 1 size lean 75-784 is 2 sizes lean
Length: 2 13/32 inches
-Tom
1950 Chevy 3100 w/ 1956 235
