4 members (66flea, Eisenholtz, Otto Skorzeny, Shardean), 70 guests, and 1 robot.
Topics128,023
Posts1,055,367
Members48,420
#860521 06/20/2012 2:46 AM
I'm trying to find the dimensions of a Carter YF metering rod..75-749 OR is there a list of published dimensions I could refer to?? Any help would be greatly appreciated. Thanks.
Pizza40
pizza40 #860607 06/20/2012 1:25 PM
I'm sure someone will probably chime in with an exact answer but until then ...
If you can't find it at the following link,shoot them an email. http://www.thecarburetorshop.com/Orderinfo.htm
The owner goes by Carb King on the forums.
BLUEMEANIE #860629 06/20/2012 2:27 PM
Joe H #860813 06/21/2012 3:06 AM
Carburetion specialist
Got your email. But since you also posted here, I will give the answer to the email here as well.
With all due respect, this is a question I won't answer. No, I am not trying to keep the information to myself, rather it is a matter of time. The dimensions are found ONLY on the original blueprints/drawings which are on microfilm. It would take an hour or so to retrieve the information, and present it in a usable form. And spending that hour could result in about 3800 identical questions for other metering rods.
As far as general specs:
Effective length 2.40625
High vacuum 0.0715
Midrange 0.062
Low vacuum 0.045
And even Carter did not have a comprehensive chart (at least it doesn't exist in the factory records in my possession).
Jon.
The Carburetor Shop
carbking #861053 06/22/2012 1:52 AM
For the Carter 937S carb,
75-749 is Standard
75-783 is 1 size lean
75-784 is 2 sizes lean
Length: 2 13/32 inches
-Tom
1950 Chevy 3100 w/ 1956 235
