1 members (baldeagle),
36
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2011 Posts: 17 New Guy | | New Guy Joined: Nov 2011 Posts: 17 | My 42 1.5 ton does not have a check valve in the vac line. How bad is this and what should I be checking for, for proper ops of the system? Where can I get a check valve ? Thanks for any help
I know that there have been some threads on hydrovacs here so if someone could post the links I would like to read up on them.
| | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | You don't need it for proper operating of the hydrovac.
All it does is to fall down into place when the engine dies, effectively leaving vaccuum pressure in the system so you will get one or two presses of the brakes with the hydrovac helping.
You can get one in most large trucks from the 40's through probably the late 60's. A lot of different makes and models used hydrovacs.
Jeff | | | | | Joined: Dec 2010 Posts: 253 Shop Shark | | Shop Shark Joined: Dec 2010 Posts: 253 | I've been told that the check valve keeps any raw fuel or contaminants in the intake manifold away from the rubber diaphram in the H-Vac unit that would shorten it's life. You should probably look into getting one for your truck sooner than later.
-Mike-
1945 Chevrolet G 506 1.5 Ton Military 4X4 1967 Jeep Cj5 with 283 SBC
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Rix42, welcome, the check valve is there to stop the hydravacs vacuum from disappearing when you have a low vacuum condition occuring in the intake manifold, such as when you're climbing a hill. Without the check valve the vacuum available to the Hydrovac would be constantly fluctuating, hope that helps. | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | 3B, interesting point, I wouldn't have thought of that. I would have figured the vaccuum would still be enough to operate the hydrovac under extreme throttle, but maybe not.
Jeff | | | | | Joined: Nov 2011 Posts: 17 New Guy | | New Guy Joined: Nov 2011 Posts: 17 | Thanks for the help. I will see I can find for a check valve. I want to see what difference it makes if any and I also read that the flow of oil or gas fumes can damage the diaphram in the hydrovac. So that alone would make it good to have. | | | | | Joined: Nov 2011 Posts: 17 New Guy | | New Guy Joined: Nov 2011 Posts: 17 | Well I checked around and came up with nothing useable sooo... Does anyone have a part number that would work for a check valve?
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | The vacuum lines are also routed with an upside down U bend mounted on the fire wall that has the top of the bend higher than the carburater. This keeps the gas fumes (heavier than air) from migrating into the storage tank and condensing back to liquid gas. Look for the parts from a donor truck. Mike B  | | | | | Joined: Dec 2010 Posts: 253 Shop Shark | | Shop Shark Joined: Dec 2010 Posts: 253 | If you are not going for a 100 pt. restoration most any modern truck uses a check valve for the manifold vacuum line to the power brakes and one of these could be adapted if you can't turn up an original.
The U bend in the line only makes sense but it never registered with me what it's purpose was. I always learn something on this site!
| | | | | Joined: Nov 2011 Posts: 17 New Guy | | New Guy Joined: Nov 2011 Posts: 17 | ok I will continue to hunt. Thanks for the help My vacuum line does loop up over the engine and down to the manifold to at least that should help with the fume problem.
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | The check valve also helps save the vacuum system when the engine back-fires through the intake manifold/carburator. If the storage tank is full of fumes it could blow... Mike B  | | | | | Joined: Nov 2011 Posts: 17 New Guy | | New Guy Joined: Nov 2011 Posts: 17 | I don't want that to happen. I'm still looking for the moment. | | |
