7 members (Otto Skorzeny, dt235sd, Cosmo, Hanks custodian, klhansen, JW51, Lostbuthaulinass),
105
Mod | | | Forums66 Topics128,059 Posts1,055,825 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | I bought a new 6 volt flasher and the blinkers worked. Then I closed the hood and they didn't. I had the passenger side on. The new flasher was real hot. All I can think of is the passenger side front hot wire is grounded. Did this fry the flasher? I didn't get a chance to check.
Any other thoughts or suggestions?
Thank you
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Aug 2011 Posts: 835 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 835 | Could be a bad flasher. I think if you had a dead short in a wire going to the light, you would have seen smoke and had some melted wires, unless you have a fuse. I think the aftermarket flasher units come with an inline fuse. Have you checked for that?
If you have a VOM it is very easy to check for a short.
Kurt | | | | | Joined: Mar 2012 Posts: 8 New Guy | | New Guy Joined: Mar 2012 Posts: 8 | Maybe try using a test light also to follow along. I rewired my 52 and the test light helped alot. I had a few bad grounds to clean up too. Just a Thought. | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | At first I was very happy to see the blinkers work then when I closed the hood all went sourer. Poop
That is when I went in the truck and the flasher was hot. I had to get a rag to pull it out. Oh, and stupid me did not put a fuse in line. Poop
If the bulb and holder did ground when I shut the hood would this happen?
Thanks guys
| | | | | Joined: Aug 2011 Posts: 835 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 835 | I don't think those flasher units are grounded to the case, because they have no ground. They are a switch. But even if they were, you would be getting a ground to ground. No short.
The thermal type are designed to work by producing heat, so if it got "stuck" it might just keep producing heat until it burned up.
You could just jump the socket with a small jumper wire and see if the lights will come on. They should burn steady. Obviously if it get hot real quick, pull it back out
Kurt
| | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | I am thinking of pulling the front running light/blinker out of the front passenger side and see if I can figure it out.
And I was so happy while the blikers worked. Poop
