2 members (Gdads51, GrandpasJimmy), 134 guests, and 0 robots.
Topics128,191
Posts1,057,364
Members48,469
Is there a way to make a foot start work like it did when my suburban was a 216 3sp 6V if so what parts do i need Thanks Tony
Stovebolt CHEVROLET
1949 Chevrolet Suburban
Non stovebolt CHEVROLET
1958 Impala Convertible
1963 Impala Convertible
MY 1949 SUBURBAN
Add a switch in the floor. Wire the starter so that when yhou press the switch in the floor it activates the starter. But it doesn't look or act much like the original floor starter.
You can mount this switch where the old starter mechanism came through the floor.
Seems to me that if the bellhousing you are using was set up to hold the foot starter mechanism, all you would have to do is put the foot starter back on, and use a 6v starter with switch as per original. Might need to change the flywheel or pinion gear of the starter to match. The 6 volt starter will work fine.
Alternatively, You could use the foot starter mechanism to hit or work a switch which will activated the starter solenoid. This should be pretty easy to do.
Kurt
The 292 will not accept the 235/261 starter- - -the bellhousing and flywheel setup is totally different. You can fabricate a fake foot start that will resemble the original pedal inside the cab with a little ingeneuity- - -just make a spring-loaded pedal that brackets to the floor in the original position, and put a push button switch under it to activate the solenoid. If you use the original pedal and rubber boot, the difference won't be noticeable to anyone without opening the hood and looking for the mechanical linkage to the starter.
Thanks for the info on the starter not bolting up and everyone else too for the advice thats is one of the coolest thing i have always loved even as a kid about these trucks is the foot activated starter si uts a must i keep that LOL
Stovebolt CHEVROLET
MY 1949 SUBURBAN
I just noticed you're using an automatic transmission. Be sure and incorporate a Park/Neutral safety switch in any starting system you design. It gets a little exciting when you fire it up in gear!
It's like pulling the arm on a slot machine u either get to pull it again or HIT the jackpot LOL
Stovebolt CHEVROLET
MY 1949 SUBURBAN
Thought I'd add to this old thread rather than create a new one. Here's what I came up with to have a foot starter with my 250/200-4R in my 57 3100. I used a foot starter switch for a tractor (Tractor Supply #0236643}. It will bolt to the floor and fit through the hole for the stock linkage. I built an adapter to allow me to attach the stock foot pedal to the switch.
Here's a pic of the parts.
And a pic of it assembled.
After installing the rubber boot over it, it should look nearly stock.
Comments welcomed.
regards,
Leon
Looking good! That's the starter switch that fits the Farmall Cub and several other early-1950's tractors that are still in use around my area.
I like it.
Comments welcomed.
regards,
Leon
I think this one should be made into a tech Tip! thumbs_up
