| | | Forums66 Topics128,041 Posts1,055,479 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2012 Posts: 5 New Guy | | New Guy Joined: May 2012 Posts: 5 | Hey guys,
I have a 50 suburban. When I bought it I knew little of suburbans. It had all the seats and they were in decent shape. However in the front the guy had removed the seat riser and made his own bracket like risers similar to 3 inch high wood blocks but made of metal and mounted the driver seat to those brackets. The jumper which looks like its from a later suburban has similar mounting brackets and it sits at the same height as the driver seat. Since I knew nothing of suburbans it looked normal at the time. I've read there is also a factory metal plate that the jumper is mounted to which is also gone on my suburban. The floors were never reeplaced so it looks like they purposley removed these peices. What can I do to correct this? Has anybody out there that has has to seal with this?
Thanks! | | | | | Joined: Apr 2008 Posts: 256 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 256 | If your trying to make the truck stock find someone parting our a suburban and buy those parts needed to convert it back to stock if your not concerned about having it 100% stock then put seats you you like and drive the heck out of it LOL | | |
