4 members (JoeDude, Gdads51, J Lucas, Shakey61), 112 guests, and 2 robots.
Topics128,032
Posts1,055,517
Members48,425
#859763 06/17/2012 3:24 AM
I have been listening to and applying the advice provided by the experts on this forum for stripping paint down to the bare metal.
So, I spent almost the entire day sanding all the old paint/primer/body filler/tar/rust/bird poop/unidentified gunk off of ONE fender. I even had to use my 4.5" angle grinder in places for some of the body filler because it was on so thick. And then........just as I was innocently rinsing the fender off with the hose, admiring the days work and congratulating myself for a job well done, it occurred to me........I HAVE TO DO THE INSIDE OF THE FENDER, TOO!
Just kill me now.......
Fiftyfifty #859766 06/17/2012 3:32 AM
The undercoating comes off nicely with the 4.5" polycarbonate disc sold by HF and a 4.5" angle grinder. 3M makes a version in purple and calls it a SandBlaster disc. Post some pics of your hard work! thumbs_up
Fiftyfifty #859770 06/17/2012 3:38 AM
ah hem... it's pronounced AhOOOmmaWTFwasithinkingwhenistartedthis
grasshopper'
Weild fast the 4.5
to reveal the inner prime
then 80grits weigh quickly on the rest
follow the inner journey of the under fender and watch the birth of Hammer and Dolly spring forth.
All is as it should be
Beers are in the fridge?
Give me ambiguity
or give me something else
Lugnutz #859771 06/17/2012 3:41 AM
Darn the luck! Putty knife and a heat gun will help get the tar off as well
....David
54barnfind #859785 06/17/2012 4:33 AM
Hey Lugnutz......I'll be on my way to HF tomorrow at the crack of dawn to make sure I'm first in line when they open. Thanks for that one! It ought to make life at least a LITTLE easier and less frustrating.
And, YOU, CASO! Or, should I call you.....MASTER? When one is searching for the inner fender, must he not pass through many dimensions not known to him to achieve one-ness with the metal?
Anyway, 54barnfind may have the right idea after all.
OR..........I have been doing extensive research on the advisability of just going with the 3-part POR15 process on the inside of the fenders after blasting off the majority of the flaking rust. I think I'll go with the silver per their recommendation. It'll surely reduce the time and frustration factor.
What say all of you?
Fiftyfifty #859786 06/17/2012 4:36 AM
By the way, CASO.......you misspelled AhOOOmmaWTFwasithinkingwhenistartedthis. You left out the "7".
Fiftyfifty #859797 06/17/2012 6:46 AM
Exactly why I disavow the "Master" label.... Just a CASO eeeek
Give me ambiguity
