12 members (gswbbc, Gdads51, Scott, frogfarmer, panel fan, FAST55, JW51, Wayne67vert, Lightholder's Dad, 48jim1ton, tclederman, 1 invisible),
70
0
Mod | | | Forums66 Topics128,049 Posts1,055,553 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2012 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: May 2012 Posts: 37 | I have been listening to and applying the advice provided by the experts on this forum for stripping paint down to the bare metal.
So, I spent almost the entire day sanding all the old paint/primer/body filler/tar/rust/bird poop/unidentified gunk off of ONE fender. I even had to use my 4.5" angle grinder in places for some of the body filler because it was on so thick. And then........just as I was innocently rinsing the fender off with the hose, admiring the days work and congratulating myself for a job well done, it occurred to me........I HAVE TO DO THE INSIDE OF THE FENDER, TOO!
Just kill me now....... | | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | The undercoating comes off nicely with the 4.5" polycarbonate disc sold by HF and a 4.5" angle grinder. 3M makes a version in purple and calls it a SandBlaster disc. Post some pics of your hard work!  | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | ah hem... it's pronounced AhOOOmmaWTFwasithinkingwhenistartedthis grasshopper'
Weild fast the 4.5 to reveal the inner prime then 80grits weigh quickly on the rest follow the inner journey of the under fender and watch the birth of Hammer and Dolly spring forth. All is as it should be Beers are in the fridge?
| | | | | Joined: Oct 2010 Posts: 171 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 171 | Darn the luck! Putty knife and a heat gun will help get the tar off as well
....David
| | | | | Joined: May 2012 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: May 2012 Posts: 37 | Hey Lugnutz......I'll be on my way to HF tomorrow at the crack of dawn to make sure I'm first in line when they open. Thanks for that one! It ought to make life at least a LITTLE easier and less frustrating.
And, YOU, CASO! Or, should I call you.....MASTER? When one is searching for the inner fender, must he not pass through many dimensions not known to him to achieve one-ness with the metal?
Anyway, 54barnfind may have the right idea after all.
OR..........I have been doing extensive research on the advisability of just going with the 3-part POR15 process on the inside of the fenders after blasting off the majority of the flaking rust. I think I'll go with the silver per their recommendation. It'll surely reduce the time and frustration factor.
What say all of you? | | | | | Joined: May 2012 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: May 2012 Posts: 37 | By the way, CASO.......you misspelled AhOOOmmaWTFwasithinkingwhenistartedthis. You left out the "7".
| | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | By the way, CASO.......you misspelled AhOOOmmaWTFwasithinkingwhenistartedthis. You left out the "7". Exactly why I disavow the "Master" label.... Just a CASO
