4 members (CuzzFuzz, baldeagle, Ponchogl, Stovebolt48), 68 guests, and 6 robots.
Topics128,021
Posts1,055,346
Members48,420
I need these parts for my 1953 GMC 450. It has the 302 engine and a air compressor on the right side, so the generator would be on the left side of the engine. I'm hoping to find out what other engines/trucks shared these same parts.
These parts were removed before I bought the truck.
An additional concern is the return spring on the throttle linkage. It looks like it may have been attached to the generator bracket. Any help is appreciated.
I have a 1952 450 with 302. The generator bracket was the same as my 48. The 48 was 6 volt I just mounted an old Buick 12 volt generator to it and added a 12 volt Regulator. The reason for using an old Buick generator is that it has a bearing in each end.
Are you staying 6 volt or converting to 12 volts???
Same bracket. IF 12 volt there are 2 different 12 volt generators available. A long and a short bolt type, both will mount on the same bracket. Get one with bearings in both ends, which can be hard to find.
You might want to consider a 12 volt Alternator.
Bracket are available at many auto part stores.
My throttle spring was also attached to the generator bracket.
I got a throttle return spring bracket from Jim Carter...#MEE295 and spring #ME459
Good Luck
Dance like no one is watching,
Sing like no one is listening,
Love like you've never been hurt.
1948 GMC FC101 1/2t Pickup w/270 and SM420
1948 GMC FC253 1t Factory 80"x9' Flatbed Dually
1948 Chevy COE 2 Ton 8'x15' Flatbed
1950 GMC 354-24 2 Ton 8'X12' Flatbed w/Dump Hoist
1953 GMC 454-30 3 Ton 8'x14' Flatbed w/Dump Hoist
1953 GMC 454-30 3 Ton Cab and Chassis
1942 Clarkator 6 MILL-44 Heavy Aircraft Tug
1942 Ford (9N) Moto Tug with 1/2 yard Loader
1947 Oliver OC3 HG-42 Tract-Crawler Bull Dozier w/6' Blade
