| | | Forums66 Topics128,017 Posts1,055,338 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2012 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2012 Posts: 60 | I need these parts for my 1953 GMC 450. It has the 302 engine and a air compressor on the right side, so the generator would be on the left side of the engine. I'm hoping to find out what other engines/trucks shared these same parts.
These parts were removed before I bought the truck.
| | | | | Joined: Mar 2012 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2012 Posts: 60 | An additional concern is the return spring on the throttle linkage. It looks like it may have been attached to the generator bracket. Any help is appreciated.
Thanks | | | | | Joined: Apr 2001 Posts: 268 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 268 | I have a 1952 450 with 302. The generator bracket was the same as my 48. The 48 was 6 volt I just mounted an old Buick 12 volt generator to it and added a 12 volt Regulator. The reason for using an old Buick generator is that it has a bearing in each end.
Are you staying 6 volt or converting to 12 volts???
Same bracket. IF 12 volt there are 2 different 12 volt generators available. A long and a short bolt type, both will mount on the same bracket. Get one with bearings in both ends, which can be hard to find.
You might want to consider a 12 volt Alternator.
Bracket are available at many auto part stores.
My throttle spring was also attached to the generator bracket.
I got a throttle return spring bracket from Jim Carter...#MEE295 and spring #ME459
Good Luck
Dance like no one is watching, Sing like no one is listening, Love like you've never been hurt.
1948 GMC FC101 1/2t Pickup w/270 and SM420 1948 GMC FC253 1t Factory 80"x9' Flatbed Dually 1948 Chevy COE 2 Ton 8'x15' Flatbed 1950 GMC 354-24 2 Ton 8'X12' Flatbed w/Dump Hoist 1953 GMC 454-30 3 Ton 8'x14' Flatbed w/Dump Hoist 1953 GMC 454-30 3 Ton Cab and Chassis 1942 Clarkator 6 MILL-44 Heavy Aircraft Tug 1942 Ford (9N) Moto Tug with 1/2 yard Loader 1947 Oliver OC3 HG-42 Tract-Crawler Bull Dozier w/6' Blade
