1 members (Hotrod Lincoln),
104
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2010 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2010 Posts: 51 | Can anyone tell me where I could find new clutch head striker plate screws for my 58? Assembly manual no. 454042. Thanks for your help. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | I've never seen clutch heads on the TF strikers, just phillips, which are available at most of the vendors, like here .... note the assembly manual was printed in '55, with a lot of specs carried over from the AD years Bill | | | | | Joined: Feb 2010 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2010 Posts: 51 | The originals for my truck are clutch head and quite worn. Can't find any from common suppliers. I've noticed the striker plates for 59 use a larger I think 6 point bolt. Also noticed these clutch heads on earlier models. | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 |
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Feb 2010 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2010 Posts: 51 | Those look like what I need. Thank you. | | | | | Joined: Sep 2010 Posts: 252 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 252 | LonnieC how did you find all those sources? I have Googled for months and only came up with the usual suspects. | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | Peter -
I did pretty much the same as you, I was just luckier. It's been a while. I probably Googled some variation of "clutch head". Plus I looked at every page of suppliers' catalogs. Screws don't always show on the suppliers' websites. Also, I may have seen some of the sources discussed on other forums (?) Always looking for more sources.
