1 members (klhansen),
107
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,062 Posts1,055,856 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2007 Posts: 28 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 28 | I am trying to remove the propeller shaft of my 41' GMC from the transmission. The shaft is exactly like figure 3 of section 18 (page 351) from the GMC 47-54' Maintenance Manual (enclosed front shaft with open rear shaft). The rear shaft is removed, the center bearing has been removed, the ball collar at the transmission has been removed but it won't slide off. I drilled a tiny hole in the front shaft housing to get penetrating oil on the shaft to loosen it from the yoke with no luck. Any help is greatly appreciated!
| | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | Can you seperate the ujoint? You need to do that then remove the bolt on the yoke so that it slides off..
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Jul 2007 Posts: 28 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 28 | I cannot access the u-joint as it is behind the ball collar. This particular collar does not slide open for access. It is factory welded solid from the front ujoint to the Center Bearing housing. if there is a bolt holding the ujoint on it is no wonder I can't remove it. However, no such bolt is shown in the manual......huh
Thanks for the feedback! | | | | | Joined: Jun 2011 Posts: 420 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 420 | you should be able to just unbolt the bolts at the back of the trans and slide that ball collar back to access the u joint u might have to get some sand paper and sand some of the 65 yr. old crap thats on the shaft, behind the cover, thats what I had to do to my 46 1/2ton to get to the u joint | | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | It there a collar on the back of the ball collar? You will need to loosen this to slide it back. It may take some persuasion to move it if its been there a while..
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Jul 2007 Posts: 28 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 28 | The ball collar has been removed. The front u-joint is connected to this shaft by a splined slip yoke. It should by all reason slide right off. The shaft housing is one piece from the bearing support at the rear of the shaft all the way to the u-joint at the rear end of the transmission. There is no apparent way of removing this from the back end of the shaft to see what is inside. I remain perplexed | | | | | Joined: Jul 2007 Posts: 28 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 28 | I referred to the housing in earlier comments as the collar. So I may have confused folks - sorry. The ball collar has been removed. The housing remains concealing the shaft and u-joint. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | In my 1942 to 46 manual it says: "Remove the four bolts which attach the universal ball retainer to the rear end of the transmission and slip the retainer back on the tube.
Remove the nuts from the bolts which attach the support bracket to the cross member. Then pull the assembly towards the rear to clear the slines to the front universal joint. " | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | deleted (wrong year)
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | DADS50, if you look at the diagram for the 1942 3/4 Ton, it doesn't slide like your 1/2 ton and there is no seal retainer. It appears that the two pieces are fused together.
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Sorry
I'll delete my post above
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | No no, don't apologize. I think this is a case that has apparently not come up before in discussion and many have thought the same as you. It is some kind of variation of their design that is different than all the rest.
| | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | Is there any way to take some pictures and post them on Webshots or something so that we can see what you are faced with?
I have done quite a bit of driveline work and I don't quite understand your challenges. Maybe its just we are calling apples oranges or something.
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Here is the start of the instruction at the bottom of the page: Front Propeller Shaft Removal and here is the rest of the instruction and an illustration Illustration Note in the illustration that the back half of the cover does not slide over the back portion, as in the half ton. The instructions are quite clear to remove the whole housing from the transmission. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I just read some more of the instruction. In order to get at the collar seal, you have to remove the hanger assembly and slide the collar over the bearing. That is quite the contraption! | | | | | Joined: Jul 2007 Posts: 28 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 28 | that is correct. there is no retainer to slide. The housing is a single piece. | | | | | Joined: Jul 2007 Posts: 28 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 28 | It is quite a contraption. By the time I get it figured out my penetrating oil I injected into the slip yoke will have had four months of working time! Thanks. | | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | Ok! Pictures are worth a thousand words and just by dumb luck, I assembled the GMC version of this setup JUST YESTERDAY!!
The easiest way to get all this apart is to unbolt the rear axle from the rear springs. Then disconnect the rubber brake line and slide the rear axle towards the rear of the truck and the splines will slip out of the rear yoke. Then open the rear ball collar and using a socket with extension remove the nut and then remove the rear u-joint. Once this is out of the way the rest comes out just like above. The joint is press fitted in so you wont be able to take apart as I mentioned before.....
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Sep 2010 Posts: 575 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 575 | I try to avoid appending to old threads - but this one seems recent enough! I pulled apart the propeller shaft assembly today and got the rubber seal off the center bearing. <pic> The two outer "dust covers" I can't seem to remove. Not really sure how to hold onto it to separate the halves. But now I've done some reading, and realized that the bearings are non serviceable, and no repacking is possible. Now I question the need to even pull it apart, other than to clean it up a bit. There is no play in the bearing, it spins freely. The rubber boot wasn't tight in the carrier - my whole reason for removal. So now I plan to buy the 3/4 ton center cushion and modify it to fit - as I read that in another post here, and the 1 ton version proves difficult to locate. Thoughts? | | |
