5 members (papas52, Bills Auto Works, Napco Man, Shade Baby, LAROKE), 171 guests, and 1 robot.
Topics128,102
Posts1,056,184
Members48,436
Ok. I've read hundreds of posts and am ready to go to boneyards to get what I need - but I need more advice. I have a stock '51 3100 with a 216, 3 speed trans, original everything. I am doing a resto. I am looking to swap the engine/trans combo for a setup with low rpm, good street ride. I've read the tech tips, and options for a new engine with same trans , or new trans with same engine and variations.
many thanks.
I want to drop a small V8 with a manual 5-speed OD. I will change the rear to a late 90s Camaro Rear with 3.23 gears, and will change to disc brakes up front. I am looking for advice on what Make/models will help make this easier with a swap of both the engine and trans. I know I may have to modify supports, add crossmember, move radiator, etc.... I can weld and do mechanicals, but do not have the knowledge of various transmissions and their pros/cons.
So, ideally I'd like to go to a local boneyard and look for a 198x/90y V8 engine and the xx 5-speed trans or 199y vehicle and get the V8 and manual trans that I can drop as a unit. I dont have a preference for a particular trans model, so long as it matches up with the engine.
1951 Chevy 3100
2 Offline
No, you are not doing a "resto" if your meaning is restoration. You are building a street rod.
Yup. Point well taken. Changed my mind from resto after browsing Stovebolt.
1951 Chevy 3100
If you aren't already I suggest surfing on over and adding the H.A.M.B. to your reading list. They are more into the rodding (as long as its pre 63)and have a bunch of threads to pick up ideas from. (not that there aren't any rodders here)
Give me ambiguity
or give me something else
try the HIPo shop, (on this website), that is where they discuss this sort of thing. Chevy talk is pretty much oriented towards this subject.
will do. thanks.
1951 Chevy 3100
ODSS Lawman
ODSS Lawman
Before we can help in giving you parts and such, we need to know what your intentions are for the truck. Will this be a Saturday night cruiser? A daily driver? A speeding bullet?
I can say that you really can have the best of both worlds. I have a resto "period Hot Rod" under my hood and I can keep up with the best of them......
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
