1 members (baldeagle),
158
Mod | | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2012 Posts: 60 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 60 | Ok. I've read hundreds of posts and am ready to go to boneyards to get what I need - but I need more advice. I have a stock '51 3100 with a 216, 3 speed trans, original everything. I am doing a resto. I am looking to swap the engine/trans combo for a setup with low rpm, good street ride. I've read the tech tips, and options for a new engine with same trans , or new trans with same engine and variations.
many thanks.
I want to drop a small V8 with a manual 5-speed OD. I will change the rear to a late 90s Camaro Rear with 3.23 gears, and will change to disc brakes up front. I am looking for advice on what Make/models will help make this easier with a swap of both the engine and trans. I know I may have to modify supports, add crossmember, move radiator, etc.... I can weld and do mechanicals, but do not have the knowledge of various transmissions and their pros/cons.
So, ideally I'd like to go to a local boneyard and look for a 198x/90y V8 engine and the xx 5-speed trans or 199y vehicle and get the V8 and manual trans that I can drop as a unit. I dont have a preference for a particular trans model, so long as it matches up with the engine.
1951 Chevy 3100 | | | | | Joined: Jan 2010 Posts: 7 New Guy | | New Guy Joined: Jan 2010 Posts: 7 | No, you are not doing a "resto" if your meaning is restoration. You are building a street rod. | | | | | Joined: Feb 2012 Posts: 60 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 60 | Yup. Point well taken. Changed my mind from resto after browsing Stovebolt.
1951 Chevy 3100 | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | If you aren't already I suggest surfing on over and adding the H.A.M.B. to your reading list. They are more into the rodding (as long as its pre 63)and have a bunch of threads to pick up ideas from. (not that there aren't any rodders here)
| | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | try the HIPo shop, (on this website), that is where they discuss this sort of thing. Chevy talk is pretty much oriented towards this subject.
1951 Chevy 3100 | | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | Before we can help in giving you parts and such, we need to know what your intentions are for the truck. Will this be a Saturday night cruiser? A daily driver? A speeding bullet?
I can say that you really can have the best of both worlds. I have a resto "period Hot Rod" under my hood and I can keep up with the best of them......
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | |
