| | | Forums66 Topics128,051 Posts1,055,730 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2011 Posts: 402 Shop Shark | | Shop Shark Joined: Dec 2011 Posts: 402 | Hi All,
I have some symptoms from test drives of the 57 3100 (3 on the tree with a disconnected OD) that I'd like to run by you to confirm a likely bad clutch.
When I drive the truck, all goes well until a fairly lengthy drive (3 miles is long for now). I notice that, as the drive lengthens, I need to put in more accelerator pedal to keep up with what feels like a gradual loss of power. Speed drops slowly with the steady gas pedal pressure. Added noise too.
When driving it the other day, at 50 mph (and about 5 miles into the drive), the shift lever popped up out of third and into neutral.
I just changed my motor mounts out, and I'd swear I can feel more vibration now than before. Don't know that this is related, of course.
Any thoughts on what to check would be appreciated.
Jim
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | doesn't sound like anything to do with the clutch ... popping out of third is bad syncros, not uncommon, and the trans could have other wear problems - the power loss may be that the brakes are tightening up with heating [dragging too much] - vibration could be bad Ujoints or something in the trans
Bill | | | | | Joined: Dec 2011 Posts: 402 Shop Shark | | Shop Shark Joined: Dec 2011 Posts: 402 | Wow,
Thanks Red58. Much more to check on. Never considered the brakes and I went completely through that system a couple of months ago. Will go through again.
Now, the issue of bad synchros is going to keep me up at night...no idea how to do that type of work and zero local sources for help rebuilding one of these. I been askin'...
On another topic, if you have time and could send a PM, I'd like to ask a couple of deluxe heater questions of you offline.
Jim | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | pm'd .... the popping out of 3rd isn't necessarily a disaster unless it's real often, I drove a 57 that way for years, just need to rest your right arm on the shifter when you're cruising, when you feel it start to move press down  Bill | | | | | Joined: Dec 2011 Posts: 402 Shop Shark | | Shop Shark Joined: Dec 2011 Posts: 402 | Thanks again,
Been doing the arm rest thing already...seemed natural. Now I just need a pack of cigarettes rolled up in my left sleeve and I'll look just like my Dad!
Appreciate the help. Returned the PM.
Jim | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | If the engine revs up as you accelerate like a sliping auto matic trans you have a slipping clutch. Make sure there is some free play in the pedal before you feel resistance of the clutch pressure. That is not directly related to the trans jumpinhg out of gear. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | Could be that after you installed the new motor mounts,you may need to readjust you're shift linkage.That may take care of the truck popping out of third gear.On a three speed trans the linkage goes between the column and the engine ,trans. When you changed the mounts that changed the shift linkage going to the trans.
Pete
| | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | Best way to check the clutch is to put it in a higher gear and push the accelerator, if the engine revs without the truck moving forward, then the clutch is not adjusted correctly or going bad. It is really noticeable going up a hill.
Sound like you have a different problem like everyone else is pointing out.
