Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
2 members (Otto Skorzeny, 1955 1 Series), 32 guests, and 5 robots.
Topics128,003
Posts1,055,243
Members48,418
#858937 06/14/2012 2:51 AM
Z
z48
Offline
Z Offline
Help needed. can,t seem to get a rad cap for my canadian 48 . Does, anyone have a # that I can take to the supplier. thank,s Doug
z48 #858938 06/14/2012 2:53 AM
Z
z48
Offline
Z Offline
sorry, to add to the previous post, doe,s anyone have tune up spec,s for a 55-62 chev 235 again thanx doug
z48 #858943 06/14/2012 3:06 AM
Flxible #859082 06/14/2012 4:33 PM
Z
z48
Offline
Z Offline
thanx Red58. I looked at the old repair and part,s manual,s. found #,s from G.M. for 1948. don,t think ayone will have cross-over to current part,s book,s. will keep looking Doug
z48 #859084 06/14/2012 4:38 PM
the link is re tune up specs, Doug - the cap you want is a zero pressure item, not common but in the dark past I did get one from NAPA, otherwise a post in the parts wanted will likely find one .... or you could check into getting the fill neck changed over to newer style so you could use a 4# cap
Flxible #859091 06/14/2012 5:24 PM
Z
z48
Offline
Z Offline
thanx Bill. kinda/sorta remembered from day,s gone by the tune-up spec,s. was the rad cap I am having problem,s with. My son has a 51,will borrow his cap and see if it fit,s. if it doe,s, then I have a template to match to. Doug
z48 #859101 06/14/2012 6:49 PM
You should be able to buy a 7lb cap at Canadian Tire. They have a valve on top that you flip up to release the pressure. If you leave the valve open it becomes a 0 lb cap.
1951 1 Ton Completed
