| | | Forums66 Topics128,018 Posts1,055,233 Members48,417 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 37 New Guy | | New Guy Joined: Mar 2010 Posts: 37 | Help needed. can,t seem to get a rad cap for my canadian 48 . Does, anyone have a # that I can take to the supplier. thank,s Doug | | | | | Joined: Mar 2010 Posts: 37 New Guy | | New Guy Joined: Mar 2010 Posts: 37 | sorry, to add to the previous post, doe,s anyone have tune up spec,s for a 55-62 chev 235 again thanx doug | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | | | | | | Joined: Mar 2010 Posts: 37 New Guy | | New Guy Joined: Mar 2010 Posts: 37 | thanx Red58. I looked at the old repair and part,s manual,s. found #,s from G.M. for 1948. don,t think ayone will have cross-over to current part,s book,s. will keep looking Doug | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the link is re tune up specs, Doug - the cap you want is a zero pressure item, not common but in the dark past I did get one from NAPA, otherwise a post in the parts wanted will likely find one .... or you could check into getting the fill neck changed over to newer style so you could use a 4# cap
Bill | | | | | Joined: Mar 2010 Posts: 37 New Guy | | New Guy Joined: Mar 2010 Posts: 37 | thanx Bill. kinda/sorta remembered from day,s gone by the tune-up spec,s. was the rad cap I am having problem,s with. My son has a 51,will borrow his cap and see if it fit,s. if it doe,s, then I have a template to match to. Doug | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | You should be able to buy a 7lb cap at Canadian Tire. They have a valve on top that you flip up to release the pressure. If you leave the valve open it becomes a 0 lb cap. | | |
