| | | Forums66 Topics128,021 Posts1,055,357 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2010 Posts: 384 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 384 | Just saw that mine was simply removed by previous owner while I was changing gaskets.
what is the actual effect by having it constantly open as it is today. The holes are just welded. And an open gasket between the manifolds. My Chevy Viking 1959Ulf Hedlund. Eskilstuna. Sweden [email protected]Also: Ford Galaxie 4 dr 1959 Ford Custom 4 dr 1964 Ford Mustang GT 2005
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Jun 2010 Posts: 384 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 384 | Exacly how it feels !!! Crap I need a new exhaust manifold  My Chevy Viking 1959Ulf Hedlund. Eskilstuna. Sweden [email protected]Also: Ford Galaxie 4 dr 1959 Ford Custom 4 dr 1964 Ford Mustang GT 2005
| | | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 1,159 | I have one!! I'll sell it to you CHEEP!! How about 20.00,since you need to cover shipping (from Iowa to Sweden?) I have a '55 261/w/235 head,but I'm POSITIVE the exhaust manifold is identical to yours. "I'm pullin for ya...We're all in this together" (Red Green)L.O.L. | | | | | Joined: Aug 2009 Posts: 184 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2009 Posts: 184 | If you have the means to give it a try why don't you fabricate a new heat riser to replace the missing one? If you re-drill the holes that were welded shut you should be able to put a new rod in and attach a flap to it. You can either attempt to make it stock and get a new bi-metallic strip as well so it functions automatically or run a cable and control it manually. When working properly it will fully open when cold and fully closed when hot so it would not be hard to manually operate....probably about the same as a manual choke, without being nearly as sensitive to position.
Tad
1946 Chevy OS 1.5ton, 1955 GMC 3100, along with other various IH,Ford,Nash,MGB,.....
| | | | | Joined: Jun 2010 Posts: 384 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 384 | I need a "new" manifold, since the old one was cracked and fixed. But not in a good way I'm afraid. I will get a "new" one from Iowa soon  My Chevy Viking 1959Ulf Hedlund. Eskilstuna. Sweden [email protected]Also: Ford Galaxie 4 dr 1959 Ford Custom 4 dr 1964 Ford Mustang GT 2005
| | | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 1,159 | Manifold shipped!! Sent you a P.M. | | | | | Joined: Jun 2010 Posts: 384 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 384 | Saw that. THANKS SO MUCH !!!
Today I will tear apart the starter and prepare for the new starter drive that is coming. Also fix the DAMNED air in my cooling system, and replace the thermostate while it's removed.
Ordered new points and resistor too and will need to set the pointers and fine tune the timing. Always something to do...
But it's fun My Chevy Viking 1959Ulf Hedlund. Eskilstuna. Sweden [email protected]Also: Ford Galaxie 4 dr 1959 Ford Custom 4 dr 1964 Ford Mustang GT 2005
