5 members (Hotrod Lincoln, Hanks custodian, Gdads51, Gray_Ghost, Maybellene), 80 guests, and 3 robots.
Topics128,066
Posts1,055,871
Members48,428
#858398 06/12/2012 10:22 AM
Does anyone know what bed would originally come on my 1950 4100 1.5 ton chevy? No cylinder on it so it isnt a dump. I think flat bed. Any one have pics of a '50 4100 I can use as reference?
boyle #858575 06/13/2012 12:24 AM
i have a 1955 1.5 ton that didn't come with a bed, and i don't believe that most 4000 series trucks came with beds; my advice is don't waste your time trying to find an original bed, as they are few and far between, build one, that is what most owners did back then and it will be your design so it can be built however you choose. wink
1949 Dodge Coronet
1955 2nd Chevy 4400 1.5 ton
1955 2nd Chevy 3100 1/2 ton
1957 Chevy 5400 LCF 2 ton
1966 Dodge D100 Sweptline
1968 Chevy P20 stepvan
1969 GMC LWB pickup
1972 GMC Sprint
1974 CP30 shorty bus
Materman #858588 06/13/2012 1:11 AM
likely the majority of 1.5T trucks from the factory would have been sold as "cab and chassis", meaning no bed - 2nd most common would have been flat decks, but the dumpers would have been aftermarket, just the PTO optionally supplied from the factory .... look thru the gallery at the 'medium and heavy' trucks from 48-54 to get some ideas, but don't expect to find many/any with factory [rounded corner] flat decks
Flxible #858667 06/13/2012 9:48 AM
Thanks guys That confirms my suspicions
boyle #858954 06/14/2012 4:01 AM
Here are some dimensions for the factory bed for your truck.
Model 4109 Cab w/stake body 105-5/8" long inside the boards. 87-5/16" Outside width of boards, inside the boards is 80-3/4". The stake rack is 38-1/2" tall.
Model 4108 Cab w/platform body 112-3/16" long and 87-5/16" wide. Dimension to the flat bed unloaded from the ground is 48-5/16". Same for the 4109 above.
