6 members (Hotrod Lincoln, UtahYork, Cletus1950, MickeyP, Gdads51, Wayne67vert), 72 guests, and 3 robots.
Topics128,179
Posts1,057,068
Members48,460
#858529 06/12/2012 10:00 PM
I cannot get the rear brakes to stop leaking. They leak at hollow bolt/brass connector area (where they connect to the wheel cylinder). I already tried new brass blocks and hollow bolts. For the sake of doing something, i just ordered more new copper washers. Any other suggestions? Thanks.
Keep in mind that most brass fittings are not meant to be reused.
I used new cylinders (from JC) when I did my '40, but all brass, brake hoses, (and of course copper washers ) were replaced. The steel line presses into the soft brass to seal. If reused, it's maybe 50/50 chance of getting it to stop leaking, although I know it has happened. Those pricy "banjo" fittings will probably need replacing. Well worth the $$$. Best of luck.
1940 Chevy 1/2 ton pickup "KC"
A day without sunshine is like, well, ..... dark!
Is there a certain torque # for the hollow bolts?
Just checked my '40 shop manual, and don't see any mention of tightness. There probably is a spec., maybe someone else has the info???
Are you by chance using silicone brake fluid? I have heard about problems with leaking when silicone brake fluid is used.
Yes, i'm using silicone fluid. This small task is getting more and more frustrating.
Interesting. I had never heard that about silicone DOT-5 fluid. I run DOT-5 in my '40 Ford (sorry guys, but it IS Chevy powered!,) and have never had a leak, but again, everything was new 20 years ago. But my truck is DOT-3. One additional comment, I have noticed that with silicone fluid, you will not get as hard of a pedal, but it stops fine and won't absorb water, etc.
Do you think the brass blocks can be reused?
