10 members (klhansen, papas52, baldeagle, 1955 1 Series, KEVINSKI, Hotrod Lincoln, TUTS 59, Gdads51, Dusty53, Lonnie),
178
Mod | | | Forums66 Topics128,165 Posts1,056,999 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2007 Posts: 98 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2007 Posts: 98 | I cannot get the rear brakes to stop leaking. They leak at hollow bolt/brass connector area (where they connect to the wheel cylinder). I already tried new brass blocks and hollow bolts. For the sake of doing something, i just ordered more new copper washers. Any other suggestions? Thanks. | | | | | Joined: Mar 2011 Posts: 457 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 457 | Keep in mind that most brass fittings are not meant to be reused. I used new cylinders (from JC) when I did my '40, but all brass, brake hoses, (and of course copper washers ) were replaced. The steel line presses into the soft brass to seal. If reused, it's maybe 50/50 chance of getting it to stop leaking, although I know it has happened. Those pricy "banjo" fittings will probably need replacing. Well worth the $$$. Best of luck.
1940 Chevy 1/2 ton pickup "KC" A day without sunshine is like, well, ..... dark! | | | | | Joined: Nov 2007 Posts: 98 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2007 Posts: 98 | Is there a certain torque # for the hollow bolts? | | | | | Joined: Mar 2011 Posts: 457 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 457 | Just checked my '40 shop manual, and don't see any mention of tightness. There probably is a spec., maybe someone else has the info???
1940 Chevy 1/2 ton pickup "KC" A day without sunshine is like, well, ..... dark! | | | | | Joined: May 2012 Posts: 1 New Guy | | New Guy Joined: May 2012 Posts: 1 | Are you by chance using silicone brake fluid? I have heard about problems with leaking when silicone brake fluid is used. | | | | | Joined: Nov 2007 Posts: 98 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2007 Posts: 98 | Yes, i'm using silicone fluid. This small task is getting more and more frustrating. | | | | | Joined: Mar 2011 Posts: 457 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 457 | Interesting. I had never heard that about silicone DOT-5 fluid. I run DOT-5 in my '40 Ford (sorry guys, but it IS Chevy powered!,) and have never had a leak, but again, everything was new 20 years ago. But my truck is DOT-3. One additional comment, I have noticed that with silicone fluid, you will not get as hard of a pedal, but it stops fine and won't absorb water, etc.
1940 Chevy 1/2 ton pickup "KC" A day without sunshine is like, well, ..... dark! | | | | | Joined: Nov 2007 Posts: 98 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2007 Posts: 98 | Do you think the brass blocks can be reused? | | |
