4 members (D B Cooper, Bill Hanlon, LAROKE, 1 invisible), 103 guests, and 1 robot.
Topics128,095
Posts1,056,072
Members48,433
#857316 06/07/2012 6:29 PM
Wondering if anyone would have suggestions on what would be the easiest fit to convert my 49 to 4wd
It's not the weight of the load, that breaks your back. It's how you carry it.
ODSS Lawman
ODSS Lawman
There are several options. First is find a NAPCO front end. Sometimes easier said then done. If you think your truck is slow now, wait til its a 4x4!
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
What weight is your 49? I believe NAPCO did produce 4x4 units for earlier 1 ton trucks. Half tons didn't get them until the were available from the dealer in 55.
It requires a few things to work so best to get all the running gear. Like SWEET said, it makes your truck extremely heavy and all those massive gears turning kills speed and gas mileage. I get about 9 mpg with a 350 V8. But nothing better than a NAPCO in my opinion!
Now you could try to place your 49 on top of a late model frame and running gear but I think you will find the frames are too wide. You might be able to shorten late model axles and make it work. But you are in some tricky territory.
The first front end I used was from a 1966 1/2 dana 44 closed knuckle (drums)that I had shortened down 3 1/2 to match the spring width. I switched to a newer dana 44 out of a 1976 1/2ton open knuckle & disk brakes.
"IT IS WHAT IT IS"
1953 Chevrolet 1/2-ton 3100 4x4
In the DITY Gallery
More images in Flickr
1948 GMC 1-Ton (now sold to someone in Hawaii!)
More photo in Flickr
1953 Chevy 1-Ton
I get about 17 mpg with my truck, with the 283 and Quadrajet carb. I'm pretty easy on the gas pedal but with tall tires it will do 65 pretty comfortably.
AD Napcos are cool.
Ed Miller
'58 Apache short Fleetside half ton Napco
Falls City, OR
Then what the heck is wrong with my truck Ed? I pulled the plugs and the engine seems to be running perfectly. I do think I have been getting better mileage lately after bumping up the timing and moving to 89 octane, but not 17! Maybe its simply because I am taking it off road a lot?
Didn't mean to highjack this thread!
one option is to cheat like I did. explore my photobucket or PM me if you want details.
Mileage: taller tires will help, smaller right foot will help more. If you go off-roading calculating your mileage is a waste of batteries in your calculator.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
Nice truck Vern!
