5 members (JW51, C10 - C90 Bill, Gray_Ghost, Leo, Hotrod Lincoln), 111 guests, and 2 robots.
Topics128,100
Posts1,056,177
Members48,436
a friend of mine has a 1948-49 (not sure, no body) truck with the original driveline in it that he's gonna let me have, i went to check it out the other day and it appears to be a 1 ton truck with the original 216ci with the 4 speed on the floor, BUT i looked at the tranny and it is real small compared to the transmission in my 55 second series 1.5 ton, so i checked the shift pattern and it only had 3 gears + reverse,no 4th gear. i figure that one of the gears is stuck but before i assume the tranny needs work i figured that since its a 1 ton i thought i should ask in this section because y'all deal with them.....i've only dealt with big bolts blush
1949 Dodge Coronet
1955 2nd Chevy 4400 1.5 ton
1955 2nd Chevy 3100 1/2 ton
1957 Chevy 5400 LCF 2 ton
1966 Dodge D100 Sweptline
1968 Chevy P20 stepvan
1969 GMC LWB pickup
1972 GMC Sprint
1974 CP30 shorty bus
Yes, for the earliest AD trucks (and earlier models too??)
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
cool!!! so are they rare!!??
1949 Dodge Coronet
1969 GMC LWB pickup
1972 GMC Sprint
Reasonably, but don't confuse rare with desirable
---All pictures---
ok, good...... that way it won't be so hard to find parts for the truck i hope.
1949 Dodge Coronet
1969 GMC LWB pickup
1972 GMC Sprint
No reason you can't swap it for a 4 speed if you wanted to.
---All pictures---
i think i will leave that in it, unless it is messed up.....it has been w/o a cab since the 80s and has sat outside since then.
1949 Dodge Coronet
1969 GMC LWB pickup
1972 GMC Sprint
Nothing in the literature indicates a 3-speed being available for a 1-ton. At least not in 48-49. The last top-loader 3-speed was in 47 1/2-tons.
Do you have a SM-420 4-speed in your 55-2nd? With reverse to the left and down? If so you know that you have to push against a spring to get it to go to the left...
The 50 3/4-ton I bought in 03 had sat for so long in neutral that it wouldn't go in any gear due to rust and corrosion built up on the shift rails/shafts.
Professional Novice
i plan on taking it and having it looked over anyway, and i did eventually figure out my 55 shift pattern....after i bought the owner's manual, lol
1949 Dodge Coronet
1969 GMC LWB pickup
1972 GMC Sprint
Does it have a small rod with a T-shaped handle on top that runs parallel to the shift lever?
Professional Novice
no, it doesn't.....should it?
1949 Dodge Coronet
1969 GMC LWB pickup
1972 GMC Sprint
If it did that would mean it was a pre-48 4-speed... The small rod is pulled up to allow it to go in reverse.
If that is a 3-speed it has been swapped.
I think...
Can you find any stamped numbers on the trans? That would be useful in ID'ing it.
http://chevy.oldcarmanualproject.com/chevyresto/4858.htm
Professional Novice
there are numbers stamped on it, but it will be a little bit before i can get them as the truck is still at my friends house.
1949 Dodge Coronet
1969 GMC LWB pickup
1972 GMC Sprint
I'm not completely sure, but I think all 49 one tons had 4 speeds. I know for fact my 49 one ton, and all the others I have seen do as well.
Moderated by  Dusty53
