| | | Forums66 Topics128,057 Posts1,055,808 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 23 New Guy | | New Guy Joined: Jun 2012 Posts: 23 | Does anyone know what bed would originally come on my 1950 4100 1.5 ton chevy? No cylinder on it so it isnt a dump. I think flat bed. Any one have pics of a '50 4100 I can use as reference? | | | | | Joined: May 2012 Posts: 574 'Bolter | | 'Bolter Joined: May 2012 Posts: 574 | i have a 1955 1.5 ton that didn't come with a bed, and i don't believe that most 4000 series trucks came with beds; my advice is don't waste your time trying to find an original bed, as they are few and far between, build one, that is what most owners did back then and it will be your design so it can be built however you choose.
1949 Dodge Coronet 1955 2nd Chevy 4400 1.5 ton 1955 2nd Chevy 3100 1/2 ton 1955 2nd Chevy 3100 1/2 ton 1957 Chevy 5400 LCF 2 ton 1966 Dodge D100 Sweptline 1968 Chevy P20 stepvan 1969 GMC LWB pickup 1972 GMC Sprint 1974 CP30 shorty bus There are three things that I've learned never discuss with people: religion, politics, and the Great Pumpkin.----Linus Van Pelt Trying to understand the behavior of some people is like trying to smell the color 9 | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | likely the majority of 1.5T trucks from the factory would have been sold as "cab and chassis", meaning no bed - 2nd most common would have been flat decks, but the dumpers would have been aftermarket, just the PTO optionally supplied from the factory .... look thru the gallery at the 'medium and heavy' trucks from 48-54 to get some ideas, but don't expect to find many/any with factory [rounded corner] flat decks
Bill | | | | | Joined: Jun 2012 Posts: 23 New Guy | | New Guy Joined: Jun 2012 Posts: 23 | Thanks guys That confirms my suspicions | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Here are some dimensions for the factory bed for your truck. Model 4109 Cab w/stake body 105-5/8" long inside the boards. 87-5/16" Outside width of boards, inside the boards is 80-3/4". The stake rack is 38-1/2" tall.
Model 4108 Cab w/platform body 112-3/16" long and 87-5/16" wide. Dimension to the flat bed unloaded from the ground is 48-5/16". Same for the 4109 above. | | |
