| | | Forums66 Topics128,154 Posts1,056,856 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2012 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2012 Posts: 37 | need some brain power, trying to find out how to modify my existing 3 spd. trans torque tube setup, to run a 3/4 T open drive line. My interchange book sats they share the same case & gears, but can't find anyone to verify. Tranny guy says they are completely different and I need to change the bellhousing too. Anyone done this? or? | | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | Going from a TT 1/2 ton setup to a 3/4 open drive there is a difference in the rear gears. You will be much slower doing this. What are you trying to accomplish?
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Apr 2012 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2012 Posts: 37 | if I go to open drive shaft, I can change the rear end to a later year W/better gear ratio selection. All I will need to do is custom the drive shaft. The rearend gear ratio is currently 411 but that could go away by changing rear end. Getting the diagrams or right info on compatibility is my challenge. | | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | Or you can install a 3:55 gear set from Patricks. That is what I did and can cruise at 65 all day long.
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Apr 2012 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2012 Posts: 37 | You are right, but if I can figure the open drive there are more options. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | All 1946 3 speeds are designed for torque tubes. In some cases a short inclosed drive line was used that would bolt to the trans and would be setup for open on the rear. Front propeller shaft
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Apr 2012 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2012 Posts: 37 | thanks, I am going to see a guy tomorrow thats been working on these for 20+ years and get his input. I think that short shaft bolt-on might be the ticket. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I did design another way to convert one of those transmissions to open drive but it takes a little machining. You can private message my if you want more info.
