8 members (mk72, Gdads51, ShopRag, TUTS 59, Hush, Otto Skorzeny, Hugh63c10, Hanks custodian),
149
Mod | | | Forums66 Topics128,042 Posts1,055,522 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2012 Posts: 5 New Guy | | New Guy Joined: May 2012 Posts: 5 | Hey guys,
My 54 pickup 235 motor makes a knocking noise when I accelerate. At idle I don't hear it. I put my hand on the valve cover and I feel the knock when i accelerate. I just had the head rebuilt and valve adjustment about 3 months ago. Any ideas why its doing this?
Thanks! | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | sometimes an exhaust leak sounds like that, I don't know how you can hold your hand on the valve cover while you accelerate, unless you have very long arms | | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | Easy enough. Stand beside the truck on the carburetor side. Put one hand on the throttle linkage, the other on the valve cover.
With the truck in neutral and running, open the throttle with one hand to accelerate the engine while feeling the valve cover with the other hand.
LOL Okay..... maybe I shouldn't have done that to ya.
You may be right about the exhaust leak. Could the timing be fast enough to have ""preignition knock"? | | | | | Joined: Sep 2011 Posts: 814 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 814 | I believe a bad wrist pin will do that. You can pull the plug wires one at a time and see which cylinder it's coming from--or if it's coming from someplace else altogether.
1956 Chevy 3200
| | | | | Joined: May 2012 Posts: 5 New Guy | | New Guy Joined: May 2012 Posts: 5 | I can actually stand at the center of the grill and have my left hand on the valve cover and reach the carb with my right hand to accelerate. I guess I do have long arms haha..
I'll check the timing, but that was also set prior to the valve adjustment.
If its a bad wrist pin, is that an easy fix?
Thanks all!
| | | | | Joined: May 2012 Posts: 5 New Guy | | New Guy Joined: May 2012 Posts: 5 | Ok..I pulled out one wire at a time and found the one causing the knocking sound. I started from the right to left. Once I pulled the wire next to the coil it stopped knocking when I give it gas. So what is it? bent rod or i something to tight? Am I going to need to rebuild the engine?
Your input would be greatrly appreciated.
Thanks! | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | rebuilding only the head often results in trouble with the bottom end .... time to open that up and find what got overstressed in it's old age
Bill | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | I had that back in March and they had not replaced the push rod guides when they redid the engine just knurled them and put them back in.
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Feb 2004 Posts: 29,755 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,755 | Knocks that stop when the ignition is disabled are most often caused by a cracked or broken piston skirt. Very rarely, you'll find the wrist pin has worn excessive clearance into the piston. Since the rod clamps onto the wrist pin on a stovebolt, a worn upper rod bushing is not a possibility on these engines. A connecting rod knock will change pitch, or sometimes become a double-knock noise, but they seldom disappear entirely. Bottom line, you need to pull the cylinder head and oil pan, and find our what's going on. Once it's that far apart, you can decide whether to do a patch-up job or go ahead with a full rebuild. Jerry
| | | | | Joined: May 2012 Posts: 5 New Guy | | New Guy Joined: May 2012 Posts: 5 | Jerry,
Now that you mention it, it does sound like a quick double knock when I accelerate then it will continue to run rough. When I drive it it sounds bad. When I unplug the ignition wire and accelerate it sounds smooth. At idle I don't hear the knock or it isn't that obvious maybe. Could it be the "connecting rod knock" you mentioned?
Thanks! | | | | | Joined: Feb 2004 Posts: 29,755 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,755 | A rod knock is caused by excessive oil clearance, either from a badly worn bearing, an out-of-round crankshaft, or both. The oil film between the crankshaft and the bearing can't cushion the rod's tendency to hammer up and down as the crankshaft turns. That problem can turn serious in a hurry, with a ruined crankshaft, a locked-up engine, or even a broken connection rod that knocks a hole in the block, so don't continue to run it much until you discover the cause of the noise. It's not going to get better by itself. Jerry
| | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | Get that thing torn down as hotrod said. If it is a connecting rod bearing failing, it won't last long. Maybe right now you can get away with replacing the rod and crank. Or may can have both repaired.
But if it runs much longer you may have some pretty serious damage. Especially if the rod comes out the side of the block. I have seen them tear up camshafts as they tore through the block. | | | | | Joined: Jan 2015 Posts: 125 Shop Shark | | Shop Shark Joined: Jan 2015 Posts: 125 | Did you ever find the problem? My 216 is doing the same thing
1964 impala ss 1949 chevy 3100
| | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | His problem was all of the above & he hasn't posted since 2012.
Brad Wrench Fetcher, PhD | | |
