0 members (),
155
Mod | | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 |  Any secrets to removing & replacing the rubber window wipes on the truck doors of a 1946 1/2 ton? They appear to be ,from the factory, pressed into a rolled bead. Harold
Harold Is a restoration ever finished? | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Harold, not SURE about the 46 but I think they are like my 52panel... and I think my 37 is this way to.
Your right in that it appears to be a "rolled bead". The rubber wiper fights into that "bead". The bead does have a slit in it. On my panel there is a little "break" right in the middle where I can get one end in it and then pull it all the way through until the other end gets there and then you pull it back the other way to where you want it. Most of the time I think I have had to cut off a little bit. The rubber comes in a big spool and the vendors cut it to length and probably give us an extra inch.
I THINK my 37, and possibly your 46, does not have that little "break" in the metal "bead" but you can pull it in from the end......since the entire metal door panel will come of to w here you can see and get to it. To get the old out just push/cut/gouge...you get the picture.
Say hi to Billie.
| | | | | Joined: Nov 2009 Posts: 639 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 639 | I put mine in this weekend. There was no way it was going to slide in from either end do to some rust/corrosion, and a coat of rustproofing paint. I forced mine strait in with a large broad bladed flat screwdriver. Worked great. | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Thanks guys, I appreciate your responses. Alvan hope you and your bride are doing fine. Harold
Harold Is a restoration ever finished? | | | | | Joined: Apr 2009 Posts: 252 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 252 | I dug the old ones out and the ends looked like they were crimped in so I opened the crimp and used some Dawn dish soap to string them end. The key I believe is make sure it's clean before the install. | | |
