6 members (55shaker, Oswald, carbking, WICruiser, Phak1, 1 invisible), 43 guests, and 1 robot.
Topics128,089
Posts1,056,009
Members48,430
#857994 06/10/2012 11:04 PM
Hello to all. Just aquired a 57 6400 and need lots of help. I solved wheel problem right away. After reading all the posts on widow makers I put out feelers and found 22.5 inch wheels. They must have come off an old u-haul truck becuase several of the tires say property of u-haul right on them. They are tubeless and made by acuride wheel company. Interesting right next to the acuride stamped logo they also say firestone. Tires are next. Any recomendations on size? Also need to rebuild front end. Need spring end bushings for sure, maybe tie rods and king pins. Where to buy? Also is the cab same as pickup? Need alot of small parts, weather striping etc.
ChuckDwyer #858020 06/11/2012 12:55 AM
3B Offline
Hy ChuckDwyer, welcome, the cabs are the same as pickups. Jim Carter is just one of the suppliers that you should check out for your required parts, hope that helps.
3B #858030 06/11/2012 1:26 AM
3B is right. Most or the parts are the same as the 55-59 task force pickup trucks. I prefer the narrow radials for my 2 tons. There are still some 9.00X22.5's out there. As for the rear, the 10 or 11X22.5's work well. I don't know my metric sizes. I have been able to get my rear tires from the local school bus barns for free. The suspension parts are a little tougher to get. I have had the best luck finding donor trucks. Good luck, sounds like a fun truck.
welcome to the site chuck good luck with your 57 6400 I have one also..
Dave
Welcome to the Stovebolt Chuck!
How wide are your new wheels? The stock 22.5" rims on the 6000 Series trucks were either 6" or 6-3/4" and could have had 8, 9 or 10.00 tires.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Mike B #858406 06/12/2012 12:16 PM
I am running 9R 22.5 on the fronts and rears of my 57.
Shane
1959 Apache 3100 Fleetside
1959 Apache 3200 NAPCO
1957 Chevy 5700 Low Cab Forward
1959 GMC F370 LCF
Another 1959 Apache 3100 Fleetside
1959 Chevy 5700 LCF
1946 Chevy 1/2 ton
1958 GMC 600
1974 Elcamino SS
