| | | Forums66 Topics128,014 Posts1,055,324 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 40 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 40 | Hi Guys,in my 1952 3100 pickup,I have a brand new 1 wire 12 volt alternator and while driving in daylight without any accessories on my battery stays charged.When I put the headlights on ,that seems to drain the battery . My battery gauge goes to the D side about 1/2 way and when I put the turn signals on ,you can see the battery needle go with the signal. Could this be a bad headlight switch? All gruonding seems good. THX | | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | Did you run a heavy wire straight from the alternator to the battery by passing the amp gauge? If so then the amp gauge will show a discharge any time something is turned on because there is no current being fed through it back to the battery.
Check your voltage at the battery with the engine running and headlights on. Should be around 13.5 volts to 14.5 volts. If so then the alternator is working.
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Sounds like the alt. is weak. Check the voltage like Roy says. Check the belt. It needs to be real tight as there is not much surface contact on the pulley with the 6 cyl. engine. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Apr 2009 Posts: 40 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 40 | Thank you so much for the help !!!!! I needed an alternator with an internal SELF ENERGIZED REGULATOR .So now the truck has plenty of power and the battery stays fully charged. I found the website through Stovebolt.....mightymo.org ............THANKS | | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | Three wire alternators are better, and easy to wire. But glad you got it charging. | | |
