3 members (Otto Skorzeny, klhansen, Bwana-Jim), 75 guests, and 1 robot.
Topics128,036
Posts1,055,450
Members48,422
#857777 06/09/2012 4:56 PM
Been playing with my truck (Maters Cousin)trying to get it sound enough for a twenty mile jaunt. Have drove it around my little town a fair bit and decided to try a secondary highway! Top end of 45 mph! It has the 4.56 gears and 4 speed trans. Transfer case is not installed as the PO installed (cobbled) the 4.56 rearend and made a two wheel drive. when I get teh correct rear end (3.90) installed, w/transfer case(Rockwell) will/should I expect improvement? I really hope so!
Stranger
Frank in Iowa
"Mater's Cousin"
More pix in Photobucket
Stranger #857786 06/09/2012 6:01 PM
the 4.56 was the 3/4T, 3.90 gears will help a lot, my 58 w/ 283 and 3.90 rear will cruise at 65-70 comfortably [if noisy].... it's a 4x4? is the front axle ratio stock?
Flxible #858364 06/12/2012 4:09 AM
Yes, front axle is the stock NAPCO unit. stock 3.90 gears. I have no idea why the PO pulled the rear axle assembly and installed the 4.56! He apparrently pulled the transfer case and driveshafts at the same time as they were in the pickup box. Like I stated, he made a two wheel drive, sorta! Sounds like getting the correct rear axle under the truck will definatly help! Thanks Bill!
Stranger
Frank in Iowa
"Mater's Cousin"
