5 members (Bill Marlow, TUTS 59, Wally / Montana, Shade Baby, 1 invisible), 80 guests, and 4 robots.
Topics128,132
Posts1,056,385
Members48,441
So I replaced the 4 rusty, crusty zerk fittings on the lower control arms of my '69 C-10 tonight...and pumped the grease to them!
Each took from 15 to 20 pumps before grease began to ooze from the rear of the "cap" (for lack of a better word) holding the fitting.
Is that normal or do I have some kind of seal that is kaputt after 43 years?
Darren
1969 Chevy C-10 Fleetside
Riding in the Passing Lane
This is normal. You grease the joints till the grease starts comeing out or the seal swells like on a tie rod end.
1972 Chevy c10 Cheyenne Super
Thanks, WR!
Darren
George, neither of the right upper control arm bushings oozed grease when I hit them. And it took VERY little grease to have them full and resistant to more. I've just replaced all 8 control arm zerk fittings, so it's not those.
Any idea what's up?
Darren
Darren
They are probably full of hardened grease & rust. Remove the fitting & poke around with an awl. Spray some penitrant in the hole & put the fitting back in. Keep pressure on the fitting till some comes out.
Sometimes warming up the bushings with a propane torch will help loosen up the old grease. Be careful not to burn the rubber seals.
Thanks, George!
Darren
Waldo, not until last night when I scraped away several millimeters of caked greasy dirt did I even know there were rubber seals under there...thanks!
Darren
