Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (Shade Baby, 55shaker, Pre '68 Dave, 1 invisible), 106 guests, and 3 robots.
Topics128,277
Posts1,058,453
Members48,490
#857276 06/07/2012 3:09 PM
I seem to be posting a lot lately haha... I just pulled the plugs on my 235. All plugs were a little lean, but the #5 spark plug was extremely rich. Any ideas what could cause this? Going to do compression test tonight. Thanks!
1954 Chevy 3100. Original 235 and Hydramatic
www.cardomain.com/ride/2344117
Dead plug or plug wire. The plug is not firing leaving the fuel unburned.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
Be unusual for only one plug to run rich while all the others are "lean". You only one carb and it services all the cylinders.
I'm with friedgeentmater... likely a bad wire and the plug isn't firing.
Residue oily on that plug? Could be a bad ring on that cylinder letting a little too much oil by it. Or maybe a little oil coming around a valve stem.
The residue was not oily, just black dust. I will check the plug and wire tonight.
checked compression on engine. #2 and #4 were at 115 but the rest were at 135. I rewired the coil and checked all wires. #5 cylinder seems to be better. still some popping on deceleration. might have to make carb a little more rich. plugs were a little light colored.
I've had success checking spark wiring using an inductive timing light. Clamp on each wire and check the rate the bulb flashes. They should all be about the same, if not you have misfire on that particular cylinder(s)
Ed
D Online: Content
You can also remove one wire at a time. If you have one not firing well, you won't notice much difference in the way it runs when it is disconnected.
40 Chevy 1/2 ton
what about the spark plug gap, it may be a little wider or more narrow.......i had a lawnmower that did that, it was a simple and cheap fix.
1949 Dodge Coronet
1955 2nd Chevy 4400 1.5 ton
1955 2nd Chevy 3100 1/2 ton
1957 Chevy 5400 LCF 2 ton
1966 Dodge D100 Sweptline
1968 Chevy P20 stepvan
1969 GMC LWB pickup
1972 GMC Sprint
1974 CP30 shorty bus
