0 members (),
108
0
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2011 Posts: 45 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 45 | Not familiar with that end of the truck. Have located a donor and if the center can be pulled using common hand tools, I would rather do that. Otherwise, I guess i'll remove the whole axle from the springs and scrap the housing when I get home. What special tools are needed to pull the pumpkin? Leaving early tomorrow.
All you can do is all you can do.
| | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | No special tools. Remove the axles, I think it is a 3/4" socket needed for the axle flange bolts. A breaker bar may be helpful. Remove the drive shaft from the yoke, then remove the bolts that hold the pumpkin to the housing, a long extension will be helpful for this part. That should be it...keep in mind that thing is heavy. | | | | | Joined: Apr 2011 Posts: 45 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 45 | Thank you Steve. Is it just the exterior bolts(10?) on the front of the housing that holds it all in place,after the driveshaft is dropped and the axles are backed out?
| | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | You will want to remove the rear cover to get all the spider gears and other carrier parts that you will need. If I were you, I'd take the whole axle. Can't hurt to have extra parts!! Plus if you hate the smell of old gear oil like I do, this will allow you to dismantle the rear in a place that is easily cleaned!
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | No need to remove the cover, all the internal parts come out with the 3rd member inone very heavy peice. Only real reasons to remove the cover would be to inspect the innards before removal and to drain the fliud out.
Bill Burmeister | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Put small boxes inside a large box & let it fall on them. Going back you will need to fasten it down to a jack. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Apr 2011 Posts: 45 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 45 | Made the trip this morning,got the center section only.It was easy using the sellers air tools. I expected leaf springs, but it had coils. What is the best method for cleaning it up? It has caked on dirt/oil/ outside.
| | | | | Joined: Feb 2004 Posts: 29,805 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,805 | Start at the local coin car wash if you can get away with it. Soak the whole thing down with lots of the tire cleaner/engine degreaser, let it sit awhile, and then hose it down with the high-pressure soap solution. If the car wash owner hasn't called the cops by then, do a final rinse with high-pressure clean water, then beat feet! Some car wash places get pretty testy about degreasing parts!
If you soak it down with a full can of spray oven cleaner first, then wait 30 minutes, the degreasing process will go a lot faster. Jerry
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I believe for certain years, one of the search criteria is automatic with coil springs.
I use a scraper and some sort of solvent on my cleanups. For motors I use a strong paint brush cleaner. Yours will be a little trickier because you don't want to get any of that on the inside. | | | | | Joined: Feb 2004 Posts: 29,805 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,805 | Getting solvent, or even hot, soapy water on the inside won't hurt a thing. Just be sure to spray it liberally with water-displacing oil (WD-40) afterwards. Jerry
| | | | | Joined: Apr 2011 Posts: 45 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 45 | Thanks for the cleaning tips guys. I have a Landa hot water pressure unit, so maybe I'll blast it tomorrow and W-D it real good, then set it in the good ol' sun.
| | | | | Joined: Apr 2005 Posts: 396 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 396 | To help everyone out in their search for these rare creatures how about pictures of the numbers on the side of the ring gear or post the numbers here.Thanks Jerry Jerry
| | | | | Joined: Apr 2011 Posts: 45 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 45 | Cleaning the exterior of the center section today. It fits well on a 5 gallon bucket,keeping the outside dirt outside. The ring gear has GM 10-41 and 1970 on the inside where the bolts screw thru.
