9 members (GMCJammer51, Materman, Lightholder's Dad, Ridgeback, Brian Moore, tclederman, jupitor, treegrower, 1 invisible),
189
Mod | | | Forums66 Topics128,080 Posts1,055,952 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#85716 12/03/2003 6:33 AM | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Funny thing, I haven't driven my truck at dark for a long time and finally when I had to, the high beam indicator light lit up though I thought I was in low beam. After pressing the highbeam switch, the dash light shined a little brighter. Switching it again, it became slightly duller but nevertheless still on. Can I assume it's just the switch that needs attention ?
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
#85717 12/03/2003 9:28 AM | Joined: Feb 2000 Posts: 5,209 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,209 | Its been my experience that when lights get bright and dull from a switch, something is not grounded proper. The indicator may be back feeding from some thing else in the light circuit. Are the headlight grounds still good? Joe | | |
#85718 12/03/2003 4:52 PM | Joined: Sep 2000 Posts: 114 Member | | Member Joined: Sep 2000 Posts: 114 | Sounds like maybe a short under the dash. The indicator normally gets power when the switch sends power to the high beam (the indicator light is on the same circuit). If the indicator is getting power when on low beam, its either a faulty switch (in which case you'd have high and low beams on together) or a dash short that is providing power to the indicator (and the high beam is drawing some power too - since its in the same circuit as the high beam - hence the dash lights get dim.)
Jim
Jim
#85719 12/03/2003 11:46 PM | Joined: Aug 2003 Posts: 264 Member | | Member Joined: Aug 2003 Posts: 264 | The indicator light gets its voltage from the high beam terminal of the dimmer switch, the other two dimmer switch connections...one from the headlight switch, one to the low beams. Check your headlights to see if both beams are on. If so, you have a problem with the dimmer switch. | | |
#85720 12/04/2003 4:07 AM | Joined: Oct 2003 Posts: 17 Member | | Member Joined: Oct 2003 Posts: 17 | You're problem is almost deffinatly a faulty ground. With your lights on dim the voltage is "looking" for a ground, it has found one through the filament of your indicator bulb. The risistance of the filament in the headlight beam drops the voltage to the indicator, hence the dim apperance of this lamp. When on high beam the lamp gets full voltage and appears briter. The voltage now is "back feeding" through something else in the circuit.
No hill for a climber!
#85721 12/04/2003 5:25 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Red Rock is right. This is a grounding problem, and one or both of your headlights is no longer grounded correctly.
Turn on the headlights and look at each bulb to see which one is burning both filaments regardless of the position of the dimmer switch. That's the one with the problem.
There are three wires in the headlight connector. High beam, low beam and ground. The ground will be short and bolted to the body somewhere near the headlight. Check that wire and its connections on both ends.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#85722 12/04/2003 6:00 AM | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | yeah, may be a ground problem [which could be in the headlite bulb itself], but I had it happen that the lil 'prism' thingie that is in front of the indicator bulb slipped out of place, and when the lights were on, the dash light showed thru the hole for the beam indicator as if indicator on dimly, and when the high beams were on, it got bright cuz the actual indicator bulb was lit - mine was originally red, but when it happened it went to 'white' [like dash lites]
Bill | | |
#85723 12/05/2003 4:05 PM | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Yesterday evening I decided to investigate the grounding issues at the headlight areas as you guys suggested but now everything is working :mad:
Not that I'm actually mad but I don't like the tricks my truck plays with me.
One interesting observation is when the indicator was on all the time (while headlights were on) I could click the highbeam switch and find very little difference between low and high beam (this was shinning my lights against my garage door). Last night when everything was working correctly,I was able to see a substantial difference between low and high.
Though it worked correctly lastnight, I know my truck is going to play with my head until I open up the headlights in investigate this.
And finally the closing chuckle... Last weekend when I was replacing my front driverside wheel cylinder, I looked up into the fender well and saw 3 bare wires going into the headlight connector. Hmmmmmmm :rolleyes:
#85724 12/05/2003 7:12 PM | Joined: Jun 2001 Posts: 793 Bondo Artiste | | Bondo Artiste Joined: Jun 2001 Posts: 793 | Cmyana, keep these posts coming. This truck stuff is great. Your photo with the spotlight has gotten me into trouble with my wife. Now I want one..............
~ Phillip 1949 GMC Suburban - 10 year project 1952 Pontiac Chieftain Convertible straight 8 hydramatic 1945 GMC half ton truck - Driver- Sold 9-15-25 1946 Chevy COE - SOLD 1-5-26 BUH BYE CHEVY! 1959 GMC Half ton long bed NAPCO | | |
#85725 12/05/2003 9:18 PM | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | TrknGMC, Did you see my last night reply under "spotlight installation" ? It was fun taking the shots moments after it had rained and the air was heavy with moisture/fog. Check it out.
But back to the high beam saga. Took my truck out early this morning while still dark and yes the indicator started coming on again, then off, then on, flicker, flicker, flicker. Yes I'm quite certain something is making intermitten contact or breaking contact. Yes another fun thing to investigate when I have a spare moment.
#85726 12/06/2003 1:24 AM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | Craig, do you have a beer or two before you work on your truck,, sometimes that may make a difference,,,,,,just kiddding,,,,Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
#85727 12/06/2003 3:27 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Hey I usually have a few beers before I reply to anything. It may not help my answers, but makes a good excuse if (when) I get something wrong...
