9 members (Hush, crenwelge, RoadsScholar, Gdads51, R&S 51 GMC, Otto Skorzeny, Hotrod Lincoln, Ponchogl, Gray_Ghost),
106
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,125 Posts1,056,343 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2011 Posts: 85 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 85 | I have a coolant leak in the front of the engine; radiator hoses & water pump look ok. I now want to check the freeze plugs, but don't know where all of them are located. Any help/diagram would be appreciated. Thanks. | | | | | Joined: Sep 2010 Posts: 575 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 575 | In the front - there's one just over the timing cover and under the water pump. <Front> There's one on the back, top center. <Back> Two on the drivers side (mine has a block heater in one) <Drivers Side> If its leaking from the plug in the front - it should be fully exposed and quite visible to see. | | |
